1Installing u-blox center on linux
There is a new version 21 of u-blox center since I used it the last time. I have tried to install it following my own steps but the software crashed every time. So I will use version 20 for my testing on debian 10, which should be fine.
Installation steps
- Install wine 6 on debian following this tutorial: https://linoxide.com/install-wine-6-on-debian-10/
- Install u-center e.g on 'c:\u-center':wine u-center_v20.10.exe- Start u-center: wine start /unix ~/.wine/drive_c/u-center2/u-center2.exe
Remember to connect and switch on the GNSS module before you start the software. Otherwise the USB-port is not correctly bound in wine. On my computer the chip connects via COM5.EDITED
I just installed u-blox center 21.08 on my windows machine out of curiosity. Apparently you need a u-blox account now for using the software. So its best to ignore this version and use the old one also on windows.
