Spectral-Database-1.0-master (3).zip
This is the latest installment to my spectral database on github, there are now 125 absorption and emission scans. PNG pics are also included relative to the particular studies being done.
x-zip-compressed -
3.19 MB -
04/15/2017 at 14:16
Download
Spectral-Database-1.0-master (2).zip
4 new raw data files added, parts 1 and 2 from; Effects of Solvents on Fluorescence of Biological Dyes done on 8/26/2016
x-zip-compressed -
1.70 MB -
04/13/2017 at 15:00
Download
Spectral-Database-1.0-master.zip
This is the begining of my spectral database collection project over at Github
x-zip-compressed -
1.49 MB -
04/13/2017 at 08:31
Download
FIXED cuvette holder FEB 2 (Meshed).stl
*UPDATED: 2/5/2017 re-designed the Raman filter slot again, I found a less expensive Raman edge filter at Thorlabs that will work just fine, so the new slot is now 25.5 x 4.45mm and 39mm deep so the filter is at 12.5mm center line.
Standard Tesselated Geometry -
1.41 MB -
02/05/2017 at 13:12
Download
25 x25 x 6mm diffraction hologrphc done (Meshed).stl
UPDATE 1/17/2017:Holographic Diffraction grating mount holder. Dimensions; 27 x 27x with a 6mm width slot for grating mount. Inlayed 2mm at slot bottom.
597.64 kB -
01/17/2017 at 23:07
Download
40mm Lens Holder Coupler assembly fixed (Meshed).stl
UPDATE 1/17/2017:Widened the dia. of the coupler and inner dia. the 3D printing came out with a little shrinkage so I had to fix that.
376.74 kB -
01/17/2017 at 23:07
Download
20mm dia locking sleeve (Meshed).stl
lens locking sleeve for 2nd lens chamber
98.71 kB -
12/22/2016 at 20:57
Download
ALL mounting holes cut dec 16 main enclsr (Meshed).stl
Re-designed Main enclosure, 203 X 152 X 74 mm without Lid. All mounting holes are pre-cut and exactly placed.
5.08 MB -
12/16/2016 at 21:03
Download
Square mirror mount assembly complete (Meshed).stl
UPDATED: 5:14 PM 12/13/2016 25 x 25 14mm/ 12mm depth @ center W/3.2mm wide thickness to accomodate silver coated mirror.
234.75 kB -
12/13/2016 at 22:14
Download
Updated CMOS camera mount DEC 13 (Meshed).stl
UPDATED @ 2:02 PM 12/13/2016 Raised the base plate 10.83mm for a total height of; 50.83mm (2") M4 mounting holes cut on bottom
1.38 MB -
12/13/2016 at 19:01
Download
32mm lens holder W 25mm inlay filter rear side (Meshed).stl
UPDATED: 12/12/2016 6:45PM Re-designed 32mm lens holder, rear face FIXED 25mm inlay for longpass edge filter/ 25mm dia x 8mm deep.
404.18 kB -
01/17/2017 at 23:07
Download
Enclosure Lid complete (Meshed) nov 19.stl
Lid for main enclosure.
694.22 kB -
11/20/2016 at 10:06
Download
