Assembly
A project log for DIY CISPR-25 LISN
Home made two channel 5uH LISN (Line impedance stabilization network) for conducted emission measurements up to 60V systems.
kevarekkevarek • 08/19/2021 at 18:17•0 Comments
Whole LISN was assembled into DIY metal box from solderable metal sheets 1mm thick, 70mm high and 1000mm long (rather permeable and very soft iron). I would recommend to make the box at least 50% bigger to allow greater inductor separation from walls. Reason for this will be clear after validation measurements. Should I build it again, I would create separate housing for each LISN as all the manufacturers do. There is a great reason for it!
Sorry for very bad dimension drawings… this is what is available.
Housing body
Housing cover
All the parts were cut from sheet using bench scissors and soldered together. This took quite a lot of patience from my wife as quite a lot of solder flux smoke was released across our flat 😊
Inductors were clamped into their spacers and mounted into the housing.
Small PCBs for input and output capacitors and resistors were milled out of standard single layer PCB.
Output side PCB with 100nF capacitor bank and 1K resistor.
Everything assembled
Detail of output side PCB. Every centimeter of wire adds significant amount of undesired behavior above ~50MHz.
Final product ready to be tested
