Validation measurements were performed using Vector network analyzer (VNA) Rohde&Schwarz ZNB 8, 100kHz to 8.5GHz. This is my first VNA measurement so please be tolerant. Should I evaluate measurement validity and error sources my guess is that any measurement above 100MHz is invalid due to banana plugs being used. Actually I think that propper LISN manufacturers cheat their validations a bit by having SMA connectors directly in the units and connecting measurement equipment there. For test setups see simulation project log.
Inter channel isolation measurement explains why it is a bad idea to place two channels into same box and why all respected manufacturers don’t do it. There is quite a high amount of crosstalk below 10MHz. This is caused by magnetic coupling of inductors through thin internal wall separating the channels. CISPR-16 requires less than -40dB though, so I consider this unit as fine.
Long story short, after performance validation I consider this home-made CISPR-25 5uH LISN as success and based on measurement results, I release it for hobby use pre-compliance measurements 😊
kevarek
