Hackaday.io Hackaday.io
Sign up Log in
3D Scanner MK2
A Raspberry Pi based desktop 3D scanner with +/- 10 micron accuracy.
jolarJolar
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2.4k views
6 comments
975 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 6
View Gallery
2.4k
6
975
22
Team (1)
  • jolarJolar
Join this project's team
  • Kickstarter: Tupel 3D Scanner
hardware
ongoing project
3D Scanner raspberry pi pi camera kickstarter
Related lists
niceasome
nice things
This project was created on 08/24/2021 and last updated 2 years ago.
Description
This scanner can scan small objects with fantastic accuracy. Its the "Mark 2" of my last Hackaday project, its slower because it requires several images, but it way more accurate.
The key components are now:
a). 2 cameras and 2 pies to make a stereo camera.
b). A projector to add structured light patterns to help the triangulation from the stereo camera.
c). A 2 axis turntable.
d). Custom written software to blend all the different views from the turntable together.
e). A huge amount of accuracy optimisation. Also careful use of memory so the high resolution uses the minimum RAM, and speed optimisations such as synchronising the cameras.
Its well calibrated too so the CAD files it produces are at precisely real world size.
Finally I'm proud of it now, so I've decided to launch it on Kickstarter to see if anyone would like one.
Original project:
https://hackaday.io/project/34116-3d-scanner
Project Logs
Collapse
  • Now available worldwide...
    Jolar • 11/23/2021 at 17:44 • 0 comments
    From today our 3D scanner is available worldwide via eBay's global shipping program (immediate dispatch).
    https://www.ebay.co.uk/itm/185171765713
    ...and all the Kickstarter orders have been dispatched.
  • Kickstarter
    Jolar • 09/28/2021 at 09:41 • 0 comments
    Well, my decade long ambition to put something on Kickstarter has been satisfied.  Less than 2 days to run - any last orders from anyone?
    https://www.kickstarter.com/projects/jontupel/tupel3d-desktop-3d-scanner
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
OR
kathietoomer wrote 08/08/2022 at 13:59 • point
Wow cool project. Can I use this printer for small appliances? I always break my countertop blender cups. It will help me write something for my users on https://blendersguide.com
stepanenkodenis wrote 01/18/2022 at 05:31 • point
Which dlp projector do you use?
benjjyman wrote 09/03/2021 at 00:26 • point
Could you please post link to the kickstarter, this is something I have wanted at a reasonable price for a while
Jolar wrote 09/03/2021 at 08:12 • point
Here it is:
Filialleiter wrote 09/01/2021 at 17:33 • point
Hello, I am keen to support your project, it looks very pomising. But if I get one of your 1st series models on kickstarter, will I be able to use it for further development and improvement or is it a "black box", especially softwaresided?
Jolar wrote 09/03/2021 at 08:14 • point
Thanks.  The software with the Kickstarter package is a black box.  May I ask what modifications you had in mind?  Would it help to publish the usb communication protocol? That would allow you to control all the hardware, for example; operate the turntable, get syncronised image capture from the cameras, with your own choice of projected image sequence.
Using an Instant Film back for the Lomo Diana F+, a 3D printed pinhole camera for speedy, if tiny, results.
Project Owner Contributor
Pinstax: 3D Printed Instant Pinhole Camera
theschlemtheschlem
Polarimetric camera with a microscope lens attached to a 3d printer.
Automated polarimetric microscope
es-pronkE/S Pronk
A senior research project to create a 3D scanner utilizing multiple raspberry pi camera modules
3D Scanning utilizing Photogrammetry
eric-linkEric Link
Optocam Zero is a Raspberry Pi Zero based compact digital camera made using off the shelf components.
Optocam Zero
doruk-kumkumoluDoruk Kumkumoğlu
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "3D Scanner MK2", please tell us the reason.
Send message
Remove Member
