Many electronic beginners are afraid of designing SMD boards and just stick to through-hole and dip components. The reason for this could be using the wrong electronic designing CAD software.
This video intends to handle you a complete, although simple example of a project using both SMD and through-hole components, design rules, tented vias, .. etc. Finally, you can download the Altium schematic and PCB files and play with them.
In this video, I will show you how quickly I designed a simple 555 timer dual LED flasher circuit diagram/schematic/board using Altium Designer. That’s a piece of cake. So let’s get started.
