Code
09/10/2021 at 21:18 • 0 comments#include <LiquidCrystal.h>
#include <Wire.h>
int pir = 7;
int pirState = LOW;
int data = 0;
int moistureSoil = 0;
//const int Death = 590;
const int Dry = 550;
//const int Ok = 480;
const int Wet = 380;
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);byte w[] = {
B01010,
B10101,
B10101,
B10001,
B10001,
B10001,
B10001,
B10001
};byte a[] = {
B11110,
B10001,
B11110,
B10000,
B01110,
B00000,
B00000,
B00000
};byte t[] = {
B01100,
B10010,
B00010,
B00010,
B00111,
B00010,
B00010,
B00000
};byte e[] = {
B01110,
B00001,
B11111,
B10001,
B01110,
B00000,
B00000,
B00000
};byte r[] = {
B00001,
B00001,
B00001,
B10011,
B01101,
B00000,
B00000,
B00000
};byte dry[] = {
B00000,
B01110,
B11111,
B10001,
B10001,
B01010,
B00100,
B00000
};byte ok[] = {
B00000,
B01110,
B11111,
B11111,
B10001,
B01010,
B00100,
B00000
};byte wet[] = {
B00000,
B01110,
B11111,
B11111,
B11111,
B01110,
B00100,
B00000
};void setup() {
// put your setup code here, to run once:
pinMode(pir, INPUT);
Serial.begin (9600);
lcd.begin(20, 4);
lcd.createChar(0, w);
lcd.createChar(1, a);
lcd.createChar(2, t);
lcd.createChar(3, e);
lcd.createChar(4, r);
lcd.createChar(5, dry);
lcd.createChar(6, ok);
lcd.createChar(7, wet);
lcd.home();}
void loop() {
// put your main code here, to run repeatedly:
data = digitalRead(pir);
Serial.println(data);
if (data == HIGH)
lcd.setCursor(7,1);
lcd.print("IH");
delay(2000);
lcd.clear();
moistureSoil = analogRead (A0);
Serial.println (moistureSoil);
if ( moistureSoil < Wet ) { // If sensor is less than Wet
Serial.println("Greater than71% : Overwatering, enough water");
lcd.setCursor(12, 2);
lcd.write((byte)0);
lcd.setCursor(11, 2);
lcd.write((byte)1);
lcd.setCursor(10, 2);
lcd.write((byte)2);
lcd.setCursor(9, 2);
lcd.write((byte)3);
lcd.setCursor(8, 2);
lcd.write((byte)4);
lcd.setCursor(7, 2);
lcd.write((byte)7);
delay (3000);
lcd.clear();
} else if( Dry > moistureSoil){ /// If sensor is greater than Wet and less than Dry (semidry)
//moist
Serial.println("Between 31% to 70% : Just right");
lcd.write((byte)0);
lcd.write((byte)1);
lcd.write((byte)2);
lcd.write((byte)3);
lcd.write((byte)4);
lcd.write((byte)6);
delay (3000);
lcd.clear();
else if( moistureSoil > Dry){ /// If sensor is greater than Wet and greater than dry
//water
Serial.println("Between 0% to 30% : Thirsty, add water");
lcd.write((byte)0);
lcd.write((byte)1);
lcd.write((byte)2);
lcd.write((byte)3);
lcd.write((byte)4);
lcd.write((byte)5);
delay (3000);
lcd.clear();
else
delay(800);
lcd.clear();}
}else
Serial.print("BYE");
lcd.clear();
//delay(1000);
if ( moistureSoil >= Dry ) {
delay (2000);
digitalWrite(LED1, HIGH);
digitalWrite(LED2, LOW);
digitalWrite(LED3, LOW);
}else if ( Wet>= moistureSoil >= Ok){
delay (2000);
digitalWrite(LED1, LOW);
digitalWrite(LED2, HIGH);
}else{
delay (2000);
digitalWrite(LED3, HIGH);
Soil humidity indicators
09/10/2021 at 21:12 • 0 commentsThe screen shows the humidity of the water through three different icons:
This one indicates that the soil is low on water and you should water your plant.
This one indicates that the soil humidity is just right.
This one shows that the soil is overwatered and you should not water plant until it's on the first icon again.
