Designed and built to regulate the usage of water in our day-to-day activities and use it in an efficient way such that every drop of water is saved.
Details
I choose to build an eco faucet as it saves water in every home and even helps people to get aware such that they start to make use of less water for daily activities.
Components
1×
Arduino UNO/NANO
Brain of the project
1×
Water flow sensor
To detect the amount of water flow
1×
Solenoid Valve
Electric valve to maintain the flow of water
Great Work! Looking forward to seeing you build on this, as well as other projects from you!
