1Daily Usage of Water
The main aim is to check the daily water usage at home and prepare a table of daily usage.
2Procedure
- Understand the use of water flow sensor and solenoid valve and make proper wiring with Arduino
- Adjust the quantity of water usage such that the required amount is dispensed.
- Use a suitable power source for the solenoid valve and make sure that the equipment doesn't get wet.
3Future Scope
- Able to make it compact and feasible for every household to have an eco faucet.
- To achieve maximum pressure with less amount of water.
