Rev4.0 PCBs are here!
12/16/2021 at 10:44 • 0 comments -
We got good n bad news
11/08/2021 at 16:12 • 0 commentsI've tested the circuit. Good news is the 10 volt boost circuit work pretty well, all electrical characters met what I wanted. Sadly the bad news is the connector seems to be happy with faced down FPC. which it's means that I need to use the connector in reversed connection. Thus the display will now facing down. To reverse this, I need to put the FPC on another side of PCB, so the display can face up toward us but face down relative to the connector. Another PCB rev, Another PCB batch. Another 2 months 😥
PCBs arrived!
11/08/2021 at 10:06 • 0 commentsafter long months of waiting. Flex PCBs finally arrived from @oshpark all the way to Thailand. And here the PCBs
(sadly I didn't get the sticker along with these 😭)
I ordered the PCBs and components!
09/30/2021 at 10:06 • 0 commentsVery very soon (probably next 2 weeks). I will receive the rev 3.1 flex board from OSHpark and probably next month I will receive the boost IC and other passive components from China. so stick around for the first prototype!
Rev3.1 board is out!
09/26/2021 at 08:43 • 0 comments -
Rev 2.2 PCB is here with some little improvement.
09/19/2021 at 04:53 • 0 commentsI changed the ground plane from solid copper into mesh-like ground plane to improve flexibility, new rev PCB can be found here at OSHPark as well as on my GitHub repo.
Moving closer to first Prototype !
09/16/2021 at 16:03 • 0 commentsRight now I be able to complete the Time / Date setting part of the watch, so overall features are
- Display Time in this format
Current Time: HH:MM:SS
- Display Date in this format, Note that XX is 01-99
Current Date: MON--01/01/20XX
- Left / Right Joystick button is for navigating through menus (now only two, Time and Date).
- To enter the setting mode, just navigate to Time menu or Date menu, and double press the center joystick button. Use Left / Right button to move the cursor (underscore as a cursor), Up / Down button for Increase / Decrease the value.
- Leap year capable, 29th FEB supported, month 13 proof.
- Left handed mode (still using in-code #define, Will make the proper setting menu later).
Something is not right...
09/14/2021 at 02:17 • 0 commentsUpdate : I came to an agreement with seller that I will bought another one with some little discount. But I ended up paid full amount by accident (I should've wait the seller for the new listing ;P). So the excess is for another cheapo 128x64 OLED display.
yesterday I received the adapter PCB. After some code debugging I be able to get the display up and running. However, the Display panel seems broken by some unknown reason. Only middle region looks normal but around them look really faint. I use the command 0xA5 to turn all the dots on and that confirmed that the display is broken. I contacted to seller waiting for reply today after I talked with the seller last night. More about this soon but here's is the image of it up and running.
Watch's PCB redesign, Connector is rotated 180 degree...
09/09/2021 at 09:48 • 0 commentsYou can get the latest PCB revision by the link at README.MD here
After long day of headache and eyestrain. I Received the connector today. Moment that I unpack it. I realized that my PCB design was wrong the whole time. instead of the connector side facing out of the board, It's facing in. So Total redesign from rev1.0 to 2.0 (still same dimension).
First Watch code is here! (very WIP)
09/07/2021 at 14:49 • 0 comments
