Hackaday.io Hackaday.io
Sign up Log in
How to recondition car battery? Video tutorial
Have you ever considered the possibility of reconditioning the batteries you have instead of throwing them away?
gregory39Gregory39
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2.5k views
6 comments
11 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 6
View Gallery
2.5k
6
11
2
Team (1)
  • gregory39Gregory39
Join this project's team
completed project
hardware
This project was created on 11/11/2016 and last updated 10 years ago.
Description
You really can recondition auto batteries back to new condition and spare yourself a great deal of cash contrasted with purchasing new ones. This includes an exceptionally modest material called Epson Salt alongside refined water. Not tap water or filtered water. You should utilize refined water to dodge mineral stores developing on the lead inside the battery. Warm 16 ounces of refined water to around 150° and disintegrate roughly 8 ounces of the Epson salts in the water. This is easy and free method that everyone can use. More information: http://batteryrecover.com
Details
Log In/Sign up to comment
Sign up with Github
OR
Paul Britton wrote 07/13/2017 at 07:07 • point
Video has been removed..
ChucklesNuts wrote 07/10/2017 at 03:08 • point
video is unavailable
Matt Lacey wrote 07/10/2017 at 03:04 • point
I'm going to assume that temperature is in Farenheit :)
David H Haffner Sr wrote 11/23/2016 at 20:21 • point
It would have been cool, if you would have explained why the catalyzing action no longer works after 4 or 5 times. A more effective method actually is, an acetic acid (30 percent solution, sometimes 50 or 60%) added to each cell, because what is really going on, is oxidation build up on the zinc substrate, on the grid cells, that react with the sulfuric acid. The sulfuric acid can be re-purposed back into the battery cells.
Remove the oxidation, and you bring the cells back to life!
Jerry Biehler wrote 11/23/2016 at 19:55 • point
This does not recondition the battery, it is a stop gap method to get a little more life but that's about it.
logxen wrote 11/23/2016 at 01:46 • point
What is "refined water"? Do you mean distilled water?
Australia's Leading Water & Waste Water Management Solutions Specialists
Project Owner Contributor
​​Water ​Storage Harvesting-Australian Tank
australiantankaustraliantank
A solar powered system for filtering and Ozone disinfecting rural water supplies for communities
Clean water for Africa
paul-scottPaul Scott
A water leak alarm hacked from a $1 window/door alarm from Dollar Tree
SqueakyLeaks
dbdB
A low-cost, solar-driven method of water purification for the developing (and developed!) world.
Vacuum Water Purification
ben-nitkinBen Nitkin
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "How to recondition car battery? Video tutorial", please tell us the reason.
Send message
Remove Member
