Six boards left if someone has TIL311 display chips and 74hc595 latches to build this RETRO project. Free, if I am allowed to list you as a beta-tester on this Hackaday site, just send your address, ( one per customer ), :-)
The way the 74hc595 latches work with the TIL311's is like this below :
//---------------------byte to control decimal points----------------------------
digitalWrite(latchPin, LOW); // set latch for data
shiftOut(dataPin, clockPin, LSBFIRST, 219); // blink decimals on
digitalWrite(latchPin, HIGH); // light up the leds
//-------------------------2 nibbles for minutes------------------------------------
shiftOut(dataPin, clockPin, LSBFIRST, mcount);// shift out the bits
//-------------------------2 nibbles for hours---------------------------------------
shiftOut(dataPin, clockPin, LSBFIRST, hcount);// shift out the bits
ok, the "HIGH CURRENT" version is up, next will be the extended life time pcb with blanking and strobe control to tweek the current draw down to "last forever" values.
