Crossfader.amxdThe m4l patch that controls the channel mixing between live/loopBy Tobias Lilja octet-stream - 119.74 kB - 10/31/2021 at 22:30 |
Eagle.zipEagle Schematic for the main PCB.By Christian Björklund, great support from Sebastian Hastrup x-zip-compressed - 383.68 kB - 10/26/2021 at 22:59 |
mapul8tor-audio_TLclone_frozen_0.5.amxdThis is a take on the m4l Mapulator/Mapul8tor and similar patches that we use for the effect setup, with the main difference it's less buggy and slightly more fancy.By Tobias Lilja octet-stream - 355.06 kB - 10/26/2021 at 22:53 |
ClipLooper_Audio_GroupTrack 0.5.amxdThe Max for live Looper. It's specifically made for the Max patch but should be clear enough if anyone wants to edit it.By Tobias Lilja octet-stream - 1.57 MB - 10/26/2021 at 22:47 |
techno_leds_0.6.inoTeensy code.By Christian Björklund and Philip Linde ino - 11.75 kB - 10/26/2021 at 22:47 |
MaxClock-0.5.maxpatThe Max patch. The executable package was to big for this site so you need Max/MSP, It's kind of good to be able to edit it anyway put here's a link to the executable: https://www.dropbox.com/s/bxewfud7xws7eit/MaxClock-0.5.zip?dl=0By Christian Björklund plain - 1.95 MB - 10/26/2021 at 22:42 |
3D_printing.zipAll the STL files and Fusion 360 project used to build the cases.By Christian Björklund x-zip-compressed - 6.42 MB - 10/26/2021 at 22:35 |
