External 24V 5A power brick (rear)
JPEG Image -
219.17 kB -
01/18/2022 at 23:38
Preview
External PSU (Internal)
JPEG Image -
250.21 kB -
01/18/2022 at 23:38
Preview
Overview showing size when using an external power brick
JPEG Image -
100.85 kB -
01/18/2022 at 23:38
Preview
MultiBench.scad
OpenSCAD script for building all parts
scad -
16.47 kB -
01/18/2022 at 23:22
Download
MultiBench Back (Jack).stl
Barrel Jack input to back instead of full PSU
Standard Tesselated Geometry -
353.01 kB -
01/18/2022 at 23:21
Download
PSU NVVV (or equivalent size) 24V 120W PSU, 3A Switch, XT60 Female Plug and in line fuse
JPEG Image -
325.41 kB -
10/15/2021 at 23:32
Preview
Wiring for meters, binding posts, barrel jack, DPS3005 and 12V/24V selector switch
Portable Network Graphics (PNG) -
661.40 kB -
10/09/2021 at 23:48
Preview
DSO150 Oscilloscope buck convertor connection and screw positions
331.48 kB -
10/09/2021 at 22:31
Preview
Image of all 3 model files connected
168.07 kB -
10/09/2021 at 19:54
Preview
Connection Diagram for Voltmeter, Continuity Checker (AtTiny85 board), selector switch and posts
755.48 kB -
10/09/2021 at 19:32
Preview
Everything you need to build a continuity tester, including code. (also see separate continuity.ino file)
347.01 kB -
10/09/2021 at 17:35
Preview
Continuity.ino
Very simple AtTiny85 Digispark board code for creating a continuity tester (just add active buzzer and ~50ohm resistor)
ino -
1.44 kB -
10/09/2021 at 17:33
Download
MultiBench PSU.stl
Back case for a 24V 120W NVVV PSU 159 x 98 x 38 mm
380.84 kB -
10/07/2021 at 21:44
Download
MultiBench Face.stl
Component mounting panel
699.59 kB -
10/07/2021 at 21:44
Download
MultiBench Back.stl
Can be a back to either the face or the back or used to join both
353.40 kB -
10/07/2021 at 21:44
Download
