inverse_sigmoid_fitting.gifAnti-Spoofing Technique for Touchless Attendance - Inverse Sigmoid Curve Fitting based on eye winksGraphics Interchange Format - 22.58 MB - 10/26/2021 at 16:42 |
sensor_fusion_output_5ItxKWF6jF.mp43D Sensor Fusion Projection OutputMPEG-4 Video - 1.36 MB - 10/26/2021 at 16:36 |
slam-head-rpi3-simple-simple-chassis_001_JCF2NrchDP.stlCustom 3D Printed part: RPI-LIDAR MountPart of the design taken from https://www.thingiverse.com/thing:3970110 sla - 170.88 kB - 10/26/2021 at 07:52 |
slam.gifLIDAR Map generated while RPi integrated with LIDAR was traversing across different rooms in the house. The maps are sequentially joined to make the animation.Graphics Interchange Format - 4.56 MB - 10/26/2021 at 16:37 |
gaussian_edited1.jpgRobot movement from x0 to x1 to x2 is characterised by 2 Gaussian functionsJPEG Image - 402.22 kB - 10/26/2021 at 16:49 |
matrix1_edited1.pngOmega Matrix and Xi vector after 2 movementsPortable Network Graphics (PNG) - 2.87 MB - 10/26/2021 at 16:52 |
matrix2_edited1.jpgOmega Matrix and Xi vector after considering landmark, L1JPEG Image - 398.12 kB - 10/26/2021 at 16:52 |
adas.pngADAS Gadget Assembled and mounted on a car. The gadget in action was captured and uploaded as another video.Portable Network Graphics (PNG) - 1.37 MB - 10/26/2021 at 16:28 |
adas-cas_architecture_FDfd15CSHD.pngADAS Collision Avoidance System ArchitectureSystem Architecture of ADAS CAS Project. Portable Network Graphics (PNG) - 64.26 kB - 10/26/2021 at 07:52 |
BOM_Vid.MOVBill of Materials Video. LED SHIM was added towards the end of the project for assembling reasons.quicktime - 35.11 MB - 10/26/2021 at 09:22 |
slam_device_assemble.mp4Hardware Assembly of SLAM Device. ADAS-CAS Gadget is also similar in terms of assembly, except for the addition of Pi Cam, and a battery that supports power delivery.MPEG-4 Video - 14.75 MB - 10/26/2021 at 09:26 |
slam_device_4q2fpXEs0U.JPGAssembled SLAM GadgetJPEG Image - 1.17 MB - 10/26/2021 at 07:52 |
Indoor Navigational Assistance.pngHolding Indoor Navigational Assistance gadget. The device would speak aloud to give navigational directions.Portable Network Graphics (PNG) - 1.94 MB - 10/26/2021 at 16:30 |
Blind Assist.JPGIndoor Navigation Device after assemblyJPEG Image - 2.31 MB - 10/26/2021 at 16:39 |
Touchless Attendance Gadget.mp4Touchless Attendance Gadget after assemblyMPEG-4 Video - 30.63 MB - 10/26/2021 at 13:21 |
touchless-attendance_high_level_diagram_gVzXhMjT21.pngHigh Level Diagram of Touchless Attendance Solution. More detailed architecture diagram is also included.Portable Network Graphics (PNG) - 563.47 kB - 10/26/2021 at 07:52 |
attendance_light_D1diFbUbPw.jpgTouchless Attendance Gadget after assemblyJPEG Image - 187.12 kB - 10/26/2021 at 07:52 |
touchless-attendance_architecture_6y2M5VSze7.pngDetailed Architecture Diagram of Touchless Attendance Solution. Twilio integration is not shown explicitly.Portable Network Graphics (PNG) - 165.79 kB - 10/26/2021 at 07:52 |
wideMainBackground.pngADAS and SLAM Assembled - Background ImagePortable Network Graphics (PNG) - 3.88 MB - 10/26/2021 at 16:33 |
maingif_HdcrS91zrU.mp4ADAS & SLAM in actionMPEG-4 Video - 860.88 kB - 10/26/2021 at 16:35 |
bom_FKxFfVwKFK.jpgBill of Materials: Components used for the project. LED SHIM is also used but not in this pictureJPEG Image - 283.59 kB - 10/26/2021 at 07:52 |
lidar-cam_sensor_fusion_JSJFZlkmEZ.pngLIDAR-Camera Sensor FusionFrontal Angular Projections used to merge LIDAR Point clouds with Camera Images in LIDAR-Camera Sensor Fusion Portable Network Graphics (PNG) - 29.16 kB - 10/26/2021 at 07:52 |
