MIDI Wind controller based on ESP32 via BLE.
It would be only a temporary solution.
The screw left is just for fixing.
The screw buttom right is for adjusting the blowing rate outside.Fastening it would make pressure higher.
The screw mid-right is nothing for right now.
The tune top connected to the pressure meter module.It's low-cast.
I'll update all BOM maybe in next version.
(Sorry for my LAZY head)
As follows,dock Printed.
Structure designed to control the incoming air.
A Simple Dock Designed for the FLT, to be print tonight.
Last night I tried Connecting miRack - A Eurorack Simulator for iOS.
MIDI CC 7 to Vel Control.
A simple ADXL345 acceleration meter added for the FTL to do some modulation.
FLAT - 0
UPPEND - 127
1st edition of PCB Recieved and wired.
Bugs & Fixed:
GPIOs 34-39 of ESP32 no PULLUP mode.4 extra resistors added.
PCB Layout fixed: D41 -> D34.
to do:
Dock design and print.
Programming:MCU.
Programming:Timer of vel-button.
View all 6 project logs
Arnov Sharma
Yang
Androiders
Yes, delete it Cancel
You are about to report the project "EUfON FLT", please tell us the reason.
