1Setup
As RTL8722DM MINI have a built in microphone on the board, there is no need for any external microphone.
Open the example, “Files” -> “Examples” -> “AmebaAudioCodec” -> “OutputSineWave”.
2Final Result
Upload the code and press the reset button on Ameba once the upload is finished.
Connect a pair of wired headphones to the 3.5mm audio jack and you should hear the generate single sinusoidal tone.
