Huh?
02/12/2015 at 05:02 • 3 commentsWell, I fixed the firmware, put a resistor to the sanguinololu to trick Marlin into cold moves, hand pasted the data into a blank bmp file, and I've got dots. Wait... what? the image i uploaded is 40 x 20 pixels, and spaced 5mm apart in the backplane of the camera. Am I picking up pulsars?
Firmware mishap
02/09/2015 at 01:59 • 1 commentWent to fire up the machine, AND I realized it only runs code from the serial prompt, NOT from gcode text. Whoops, may need an easier way to get around the Marlin hotend temp warning/shutdown. I'll fix it asap
time to get back on it
11/15/2014 at 16:40 • 0 commentsI'm mostly done moving, and if I find the box with my tools in it, the version 1 detector should be twitching soon.
