The original rubber antenna must be tuned!
12/23/2021 at 10:36 • 0 commentsHi all!
I've found that the original antenna of the LILYGO® TTGO T-Beam is tuned at around 470MHz and that at 433.750 MHz the return loss is -3dB (half power in transmission is lost).
See how I solved in the "Details".
Guido
