2.4 + 5G Dual-band WiFi Analyzer
A dual band WiFi Signal Analyzer that help you understand your household WiFi signal status and more
Public Chat
Wanna see what's going on in both 2.4 G Hz and 5 G Hz band? Use this WiFi analyzer to give you insight to your household WiFi signal
This project is using an Ameba RTL8722DM_MINI with duab-band WiFI and BLE5.0
RTLWiFiAnalyzer_updated.ino
ino - 11.30 kB - 12/24/2021 at 07:42
Download
  • 1 × Ameba RTL8722DM_MINI microcontroller
  • 1 × Circuit board / breadboard
  • 9 × jumper wire
  • 1 × TFT LCD SPI Display 2.2" (ILI9341)
  • Check out the latest update! #1
    SimonXi • 01/05/2022 at 14:18 • 0 comments
    1. Check out the latest update! #1 at
    https://hackaday.io/project/183416-5g-wifi-kits
  • What this project is about
    SimonXi • 12/24/2021 at 07:49 • 0 comments
    This project is about building a portable dual band WiFi analyzer that help you see through the invisible RF world and understand the WiFi signal in your household.
    With a SPI LCD display, you can bring it to any room and location, and start scanning the environment.
    The image displayed on the screen is dynamic , inlcuding WiFi signal strength, channel, and name , with each WiFi signal colored differently. Thus as you roam around a house or building, you will be able to see WiFi signal changing dynamically, revealing the WiFi signal in your close proximity.
View all 2 project logs
View all instructions
