Check out the latest update! #1
01/05/2022 at 14:18 • 0 comments- Check out the latest update! #1 at
What this project is about
12/24/2021 at 07:49 • 0 commentsThis project is about building a portable dual band WiFi analyzer that help you see through the invisible RF world and understand the WiFi signal in your household.
With a SPI LCD display, you can bring it to any room and location, and start scanning the environment.
The image displayed on the screen is dynamic , inlcuding WiFi signal strength, channel, and name , with each WiFi signal colored differently. Thus as you roam around a house or building, you will be able to see WiFi signal changing dynamically, revealing the WiFi signal in your close proximity.
