Check out the Acordeonador in action here:
See what happens when the Acordeonador is amplified!
Musical instrument without batteries!, created with the motor of a PC CD player and a piano generated with the incredible 555
Whoa, this is the coolest idea I’ve seen in a long time. Simplicity and creativity. Will be building one with my 6yo: great lessons about reusing parts, concepts behind making electricity, basic electronics and an opportunity to introduce the honorable 555.
Hardest part will be the wood veneer, a nice touch!
Thanks for sharing.
:-D that made me chuckle! Awesome! You crazy person you :-D
Good idea and cool instrument ...
..but there is a drawback the generator is at least as loud as the instrument itself
fdufnews, see what happens when I amplify the sound! I could do a recital in big stadiums, although I should practice a little more. haha https://youtu.be/jFdNWro2dUU
With the amplifier it sounds a bit like a bagpipe.
Sure, a little more practice will help.
May I suggest using pots instead of fixed resistor to tune the acordeonador.
This is really a cool idea of using an cd player mechanism like a harmonium
I love how you wired the circuit in a spiral wire design kind of like a bomb which makes the project look even more attractive 😀 !
Thanks Rudraksha! I had to find a nice solution to generate the bridges! :)
Admirably goofy example of actually making a real thing from an idea. And a little flourish with the wiring goes a long way for well dressed presentation.
...I guess I'm appreciating being confronted with how rarely I remember that motors are generators...
