It works
04/27/2023 at 23:05 • 0 commentsController works without any big issues. I have few ideas for improvement, but for now work is finish.
TODO
01/04/2022 at 22:20 • 0 commentsThinks to do to make this project in close state:
- make some distance to tighten PCBs with deflection and prevent any shorts [DONE]
- remove all unused pin header from nucleo [DONE]
- clean PCBs after soldering and coat with something to prevent short
And the most important:
- intall in machine and make it all works. [DONE]
First test
01/04/2022 at 22:16 • 0 commentsAll axis are working, but I have only one controller on hand:
Mechanical construction
01/04/2022 at 22:15 • 0 commentsAt the beginning I want to mount PCB, screwing it directly. But because of quite big size I change my mind and make aluminum L-bracket to fix PCBs.
To have better contact with ground in electric cabinet I decide to make long screws (piece of aluminum with threaded holes and glued hex screw on one side and piece of threaded rod on other)
