Don't know what this Ameba board (BW16) is capable of? Watch the short clip below,
To deploy a IoT microcontroller is often a pain as it requires portable power supply and efficient power regulation, and also to work well with most sensor and actuators, the pin pitch has to be breadboard friendly meaning 2.54mm apart from each other. To achieve this, I design this Ameba Stamp module, and it features,
1. Add power circuit and battery connector to easily provide the power the IC needs
2. Re-map the previously 2mm pitch pins to breadboard-friendly 2.54 pitch pins design so as to better work with other electronic components
Both the schematic and PCB are open-source, and link is here,
fuzix can run on this?
