probe-pcb.kicad_pcb
kicad_pcb - 9.55 kB - 02/18/2022 at 18:29
Download
socket.step
step - 32.29 kB - 02/18/2022 at 18:29
Download
main-NPTH.drl
.5mm endmill for the needle holes, .8mm for the notches and header pins
drl - 289.00 bytes - 01/23/2022 at 15:01
Download
main-Edge_Cuts.gbr
I used a 2mm endmill, but other sizes will work
gbr - 875.00 bytes - 01/23/2022 at 15:01
Download
socket.stl
Print with opening on the bed
Standard Tesselated Geometry - 49.11 kB - 01/23/2022 at 15:00
Download
aligner.stl
Standard Tesselated Geometry - 2.43 kB - 01/21/2022 at 14:50
Download
