Well, this happened...
04/23/2022 at 07:06 • 0 commentsNothing much to update on the project as yet, I've had a few distractions. I just noticed I had not visited the project since I had scooped up a Tesla 2021 Model 3 Performance. So now I have a long range charger burden... better get cracking on the project, especially since my net metering trued-up this month and my electric bill was $3268.72!
S/P Nomenclature
01/27/2022 at 04:38 • 0 commentsJust reading some forums, realized I should probably clarify my baseline battery would be called 2P 16S, implying a single 48V battery and BMS, with 2 cells paralleled then strung in series.
Apparently the ? common ? nomenclature would mean 16S 2P would be two 1P 16S batteries in parallel, implying the need for two BMSs, and corresponds to using something like a pre-build off the shelf battery like SoK or EG4. Note the EG4LL 51.2V 100Ah rack mount batteries at Signature Solar et al are rated to be paralleled up to 16 packs -- not sure about others like SoK.
Also, not sure if Daly Smart BMS 250A model which I have on hand can be paralleled. It would be awkward to build 4P 16S with one BMS as the layout I have planned requires 2 shelves to do that - bus bars and balance leads would be all over the place. Anybody know if you can take two 250A Daly BMS batteries as "2P 16S 2P" ?
I know series stringing isn't allowed on a lot of 12V batteries because the balance circuits in certain conditions can see the full series voltage, e.g. 48V, while their controller chips can only handle much lower voltages, since they were designed as stand-alone 1S 12V batteries.
Inverter Selection
01/22/2022 at 15:21 • 0 commentsAfter comparing a great many recommended units, I settled on the GroWatt 12 kW 48V 150 VDC 120A Off-Grid Inverter, which is actually a rebranded Sunrino SP Series low frequency split phase inverter. GroWatt has their own designs that use high frequency conversion technology, but have their own quirks. Decoding the part description, the primary inverter in my system is 12 kW continurous output with split-phase 120/240 VAC output as is the standard residential service voltage in the United States. This allows 120V or 240V circuits at the output. Battery nominal voltage of 48V (Lead and Lithium are supported), 150 VDC solar input (open circuit voltage of string), and 120A battery charging circuit.
The 150VDC input limitation is one of the biggest drawbacks to this particular model. My bifacial 410W panels are 49.9V open circuit maximum. This means I am maxed out at 3 series panels, which is unfortunate as it means using combiner boxes and paralleling strings. This model supports two independent MPPT tracker inputs.
The battery charger of 120A x nominal 48V battery works out to 5760 Watts maximum being pushed into the battery storage. The maximum PV array power for this model is 7000 W. Recall I have a full pallet of 30 x 410W panels. It took reading this spec to realize that I wouldn't be able to get by using a single inverter with my 12,300 W panel array! I went back to Signature Solar's website to find the 12 kW models were sold out, but an 8 kW was available. I figured this would not be too much of a compromise, as this could be dedicated to my 32 Amp EV charger. Both units have the 7000 W solar input limit, 120 A battery charger circuit. Both units have the ability to charge the battery from the AC utility, with the significant difference between the units being a 70 A limit on the 8 kW model vs a 100 A limit on the 12 kW.
I don't intend to use AC charging unless absolutely necessary, but it is a nice-to-have that I can use a relay control to allow charging if the battery gets low at night and control the time of charge so only "super off-peak" 12am to 6am rates are used. In case of a cloudy week with poor solar output, I can still use grid power and use the battery to time shift the load. This is still an off-grid use, as the inverters cannot supply power back to the grid.
The Lithium Iron Phosphate cells I am using are EVE 280 Ah cells, with a standard charge rate of 0.5C, or 140 A. The charge rate of the battery is really what drives a lot of the ratings specs it appears, from 7000 W limit to the solar array to the 120 A, 5760 W charging circuit.
