This is a very interesting yet simple project for charging battery safely by making Battery Management System.
Gerber_PCB_BMS _2021-10-03.zipx-zip-compressed - 43.38 kB - 01/22/2022 at 18:11 |
Step 2: Get all the Components Listed below images.
Step 3: Place all the components on PCB and solder it properly.
Step 4:
Step 5:
Step 6:
Final step: Connect the 12v adapter to the circuit, your DIY BMS is now ready to charge your batteries.
New users will also get some coupons while registering at JLCPCB via this blue link.
Thank you for reading this guide, hopefully, this guide provides full steps to help you to create your own DIY BMS. If you have any questions please post them in the comment section below.
Got a schematic? I wonder if this would be safe to use with LiIon batteries.
