The JeremFuge Bêta finally build !
11/25/2016 at 09:26 • 0 comments -
Power supply box
11/25/2016 at 09:11 • 0 comments -
The box for the centrifuge
11/25/2016 at 09:07 • 0 comments -
Electronics without LCD
11/25/2016 at 08:49 • 0 commentsThe cables for the LCD are still welded here, we still have to remove them to have a clean JeremFuge Bêta.
The breadboard with the cables welded
11/24/2016 at 22:23 • 0 commentsThe inside of the JeremFuge !
Léon and Adrien welding
11/24/2016 at 21:16 • 0 comments -
The final draft of the centrifuge
11/24/2016 at 20:28 • 0 commentsWith the proper Arduino code, we can use the centrifuge completely. It just doesn't have the soldered joints and the box to present it in a nicer, more practical way.
Testing the LCD
11/24/2016 at 20:26 • 0 commentsThis is actually the centrifuge without the motor and the power supply. This allows to change all the settings and display it on the LCD.
Using the push button as a on/off for a LED
11/24/2016 at 20:24 • 0 comments -
One of the draft for the final centrifuge
11/24/2016 at 20:18 • 0 comments
