"Mom is coming" Notifier
Can't get notified the cases of storming the room? Ok! I gonna help you via "Mom is coming" notifier project with the help of 1Sheeld. :D
when someone approaching the room, your phone will notify you with "vibration" & saying "Mom is coming".
I make a project using Arduino, Ultrasonic sensor and 1Sheeld (which allows you to tap into your smartphone's sensors and capabilities and lets you use them in your Arduino projects. Basically, It is a hardware shield that sits on top of your Arduino board and communicates over Bluetooth to 1Sheeld app, to transfer data between it and your smartphone.)
Step 1: Materials
Hardware:
1- Arduino board
2- 1Sheeld and Android Smartphone/Tablet
3- Ultrasonic sensor HC-SR04
4- Jumper wires (Male to Female)
Software:
1. Arduino IDE (you can download fromhttps://www.arduino.cc/en/Main/Software)
2-You need to download and place 1sheeld library and 1Sheeld app from here:-http://1sheeld.com/downloads/
3- Download Ultrasonic library fromhttps://github.com/JRodrigoTech/Ultrasonic-HC-SR04...
Step 2: Code
Download it directly from"Mom is coming" GitHub repo
or c&p
****************CODE***********************
//Connect SRF 04 to 1Sheeld like this:
//Vcc >> +5 ..... Tri >> digital pin #12 .... Echo >> digital pin #13 .... GND >> Gnd
#include <VibrationShield.h>
#define CUSTOM_SETTINGS
#define INCLUDE_TEXT_TO_SPEECH_SHIELD
#define INCLUDE_VIBRATION_SHIELD
/* Include 1Sheeld library. */
#include <OneSheeld.h>
/* This pattern waits for 1 second and vibrate for 2, 3 times. */
int pattern[6] = {1000,2000,1000,2000}; int patternSize = 6;
#include "Ultrasonic.h"
Ultrasonic ultrasonic(12,13);
int distance;
void setup()
/* Start communication. */
OneSheeld.begin(); }
void loop() {
distance=ultrasonic.Ranging(CM);
// I make detection distance < 50 ... but you can change it as you want From 2cm to 400 cm
if (distance < 50)
/* Vibrate as the first pattern once. */
Vibration.start(patternSize,pattern);
/* Wait for 3 seconds. */
OneSheeld.delay(3000);
/* Stop the vibration. */
Vibration.stop();
TextToSpeech.say("Mom is coming");
Step 3: System Diagram >> Link it up
1-Install 1sheeld app on your smart phone. (you can install it directly from Play Store).
2-Connect the 1sheeld over the arduino board.
3-Connect the Ultrasonic sensor HC-SRF 04 to 1Sheeld like this:
4-Download 1 sheeld library into Arduino IDE.
5-Write the code on Arduino IDE after adjusting the detection distance from 2cm to 400 cm( I make it if < 50), connect Arduino board to PC and upload the code into Arduino board.
(Hint: Take care about Upload mode and Operating mode of the 1 sheeld board also Arduino UNO working on 5V).
6-Connect 1sheeld mobile app to 1sheeld board, select the required sheelds(vibration - text to speech) from 1sheeld app, and make a test.
Schematic
Congratulations, Now you do it yourself... :)
Any comments and suggestions will be welcome.
Schematic
Portable Network Graphics (PNG) - 178.25 kB - 11/20/2016 at 17:14
Preview
  • 1 × Arduino
  • 1 × 1Sheeld
  • 1 × Ultrasonic HC-SR04
  • 4 × Jumper wires (Male to Female)
  • 1 × Smart phone
  • 1
    Step 1
    If this is your first time using 1Sheeld, I recommend you start with the getting started tutorial first to know how to use 1Sheeld.
    For more advanced projects ... from here
    To order 1Sheeld ...from here
View all instructions
ensafatef wrote 11/20/2016 at 17:33 point
