EEE Enclosure
03/09/2022 at 17:14 • 0 comments![]()
It's time to launch OpenSCAD to make a dish for my spaghetti.
The main LCD of EEE is just 0.96' and it's a bit tiny to see from 1~2 meters away.
So I decided to use a trick for enlarging the display visually; a Fresnel lens.This CRT-like shape is actuallyoriginated from the dimension of the lens I've bought.
Let's see this trick works as expected or not.
Drawing schematics, soldering spaghetti
03/07/2022 at 16:09 • 0 comments![]()
![Spaghetti? Spaghetti?]()
Spaghetti? ↓↓↓
Spaghetti! The schematic and KiCad files are available under https://github.com/likeablob/endless-endless-eight/tree/main/kicad.
Finally it's running stably (hopefully)
02/23/2022 at 16:39 • 0 comments![]()
(Battery voltage, Brightness, millis() reported, respectively) Still in stability testing by leaving the breadboard circuit by the window.
It was a bit cloudy day but from the log, the device successfully has completed 6 episodes (24 min each * 6 = 144 minutes) of EE. Also based on the battery voltage observed, the battery has been charged in total eventually.
likeablob
