1Obtain BIOS upgrade files
Download the following software package from Fujitsu:
2Get a SystemRescueCD ready
Obtain it here:
https://www.system-rescue.org/Download/
use unetbootin , Balena Etcher, dd, emacs, vi or an electron microscope to put it on some kind of media to boot your S900 from
Unpack the files obtained in Step 1 to your boot medium
3Fire up flashrom
flashrom -p internalthis should tell you if compatible programming hardware was detected and what kind of FLASH ROM was found.
Note which detected part numbers match the FLASH ROM on your motherboard best for the next step.
4Save FLASH ROM contents as a backup for (perceived) safety
Save FLASH ROM contents as a backup for safety (or is it perceived safety? When the device is bricked, it will not run flashrom anyway. Ah, whatever... Thou shalt make backups.)
flashrom -p internal -c "MX25L3206E/MX25L3208E" -r /path/to/yourfile.bin -V![]()
5Programming, finally
flashrom -p internal -c "MX25L3206E/MX25L3208E" -w /path/to/D3003-S1.UPD -V![]()
This screen will give you some hacker cred, show it to your friends on every occasion:
6Reboot
