![](https://cdn.hackaday.io/images/7517171677051610935.jpg)
![](https://cdn.hackaday.io/images/5594781677052051679.jpg)
![](https://cdn.hackaday.io/images/3561611677052069260.jpg)
Well time to open it.
![](https://cdn.hackaday.io/images/7894631677052188906.jpg)
![](https://cdn.hackaday.io/images/2380641677052342168.jpg)
![](https://cdn.hackaday.io/images/113981677052974070.jpg)
The S+ and S- have a small C1 capacitor inbetween them, so I probably should also add that into my PCB design since a £1.50 scale is probably cutting as many corners as it can (thus, if the cap wasn't needed, it would have been ommited). As expected, the LCD contacts the board via pads. While transparent, the LCD is quite a bit darker than just clear acrylic or something, likely to do with polarisation. Here's it infront of the glossy white box:
![](https://cdn.hackaday.io/images/6982171677052533210.jpg)
The LED doesn't magically look really bright though. I've put this next to the glossy white box so you can see the exposure level. The diffuser film (that's over the clear plastic) is quite the dust/lint magnet, but it easily wipes off.
![](https://cdn.hackaday.io/images/94471677052618417.jpg)
![](https://cdn.hackaday.io/images/2893411677052689382.jpg)
As you can see, there's a tiny trace of threads in the 4mm holes. It's kind of like Fusion360's textured threads IRL.
Anyway, the dimensions are still the same 6 x 9 x 45mm I hoped for. The thickest height is 7.3mm but I'd use 7.5mm in CAD. The wire relief on the side stops 4mm from the edge. Wires for V+, S+, S-, V- are red, blue, white and black respectively. Wire relief blob is an extra 1.6mm and the wires are 0.64mm diameter and around 10cm long.
