[L] Increased vias to 0.3 : 0.45mm
A project log for Tetrinsic [gd0041]
A motorised fader that is continuous, pressure sensitive, haptic and water resistant.
kelvinakelvinA 06/24/2023 at 20:410 Comments
Now that was effort. It was mostly straightforward, but there were vias inbetween passive pads that would no longer fit. I had to move the AAT101 down 0.4mm to make the available space. It shouldn't affect the Tetrinsic CAD model all too much.
I also had to tap into the GNDPlane for 2 more signals. Still, the pour coverage seems good.
It seems that 5 boards are £1.72, 10 boards are £5.50 and 15 boards has some £19 engineering setup fee. I think I remember seeing something about the SMT service having a limit of 50*50mm, so perhaps I should actually panelise 4 into one larger board. The image above is for 10 boards, of which 2 would be spare.
When everything is in the checkout, along with the coupon, and using the cheapest shipping method:
Fedex, the next fastest delivery option, increases the total to £25.
