[R] Tube printing
07/03/2022 at 21:58 • 0 commentsQuick introduction
So I'm thinking of any new possible features that the Slime could do and I realised that I could have 1 Slime at 0 degrees and the other at 90 degrees to use the extruder motor of the second on as a 6th axis. That reminded me of the ribbon nozzle I talked about a few logs ago and looked around for internet mentions and other variable nozzles. Quickly, I found the first variable nozzle I ever knew: the SmartNozzle.
"While I'm here at this site, I might as well look to see what the 2022 entries are." I thought, and there I found the tube printing hotend.
Printing in tubes
So my university just happens to have a tube 3D printer that I've known about for months but didn't know if it was some secret prototype so never said much about it. I could never quite work out how it worked until now, but I have seen it printing and the prints it's made:
Most recently, it seems that they're trying different colours instead of 2 sets of clear filament to colour the parts
[R][M] Slime Bearing
07/03/2022 at 03:13 • 0 commentsThe more I model, the more it looks like a snail. "Slime" was only supposed to be an internal name, technically speaking.
I did some research into bearings to see if there is a bearing I should be using instead of the classic deep groove ball bearing. It seems that "lazy susans" start at 140mm so they won't fit and slewing rings seem expensive compared to that massive 6210 bearing that costs a fraction.
I found out that there's all sorts of gadgets that have been created for the installation and removal of bearings:
Considering that 2 Slime's come together for the milling tool, I probably don't have to worry about axial forces as much as I originally thought. The bearing, according to SKF, is 460g but it should mean that:
- 3 axis printing should be unaffected by the V axis (robotic arm 3D printers I'm looking at you)
- The centre of mass should move closer to the pivot
- The large steel outer ring should serve to further stiffen the Slime without having to get (custom) metal plates.
To finish, I'm thinking that room-temp air will be pumped through the bearing and wires will be bundled with the bowden array. Oh and with a tool distance of 70mm, there are no collisions when getting a tool off the Tool Bar.
[M] Tool Plate with the 868 pogo connector
07/02/2022 at 20:15 • 0 commentsSo a while ago, I decided to keep "Tool Plate" and "Tool Plate With Dowels" as two seperate files, thinking of performance. Well I don't think 6 extra cylinders per tool is going to have a noticable effect, so I unlinked "Tool Plate" inside "... With Dowels" and will now just use a single file.
[M] 868 Pogo Connectors
07/02/2022 at 18:46 • 0 commentsI'm planning to use the 868-22-004-00-011101 and 868-10-004-00-012000 connectors.
[R] Bigtreetech Manta M8P
07/02/2022 at 13:36 • 0 commentsThe new board is finally out: https://www.aliexpress.com/item/1005004478452192.html
There isn't yet a listing for the Manta M8P by itself, but looking at the M4P, I'd assume that it'll cost £46, which is currently a tad under the Octopus Pro.
Now there are some notable features on the OctPro that aren't on the M8P by the looks of things:
Knowing this, it seems that there is almost equal justification for M8P+OctPro or dual M8P, though I don't think Klipper supports toolheads using the OctPro CANbus at the moment so dual M8P might be better if I didn't already have an OctPro.
As for the CB1, the standard price is a tad under the price of the Orange Pi Zero 2, which has the same H616 processor and 1GB of RAM. There's also an optional heatsink that covers the whole thing for another £5.
[T] Tool Pogo Pins
07/02/2022 at 01:34 • 4 commentsFor recurring costs and reliability (and probably physical space), the less pins I need to use, the better.
I'm thinking that
- +24V
- Main tool GND toggle
- Always-connected GND
- Thermistor
would cover my use cases, though a 5th one for nozzle/drill bit location sensing, as seen in the video below, would be a cool feature. If there's anything I can do to automate calibration, I'd like to further explore that solution.
I'm thinking that a wireless method such as NFC or IR could be used for controlling non-realtime features, like turning on an LED or fan on the tool that is powered by an on-tool regulator from 24V input. For mechanical actuation, such as the plunger for the chocolate tool, I'm thinking of utilising sensorless homing on the extruder motor to detect end limits. As for something like an inkjet tool, there probably wasn't ever going to be enough pogo pins anyway (the max is 6). Hmmm I wonder if those new CAN bus board things I've been hearing about could present a solution. I feel like that has the potential to drastically increase the per-tool price though. For the spindle, I'm thinking that the motor controller would have to be on the tool.
I'm planning to use the same style pogo connector as MihaiDesigns. I haven't yet been able to confirm that they allow up to 9A of current, but can confirm that they're rated over 1 million cycles.
I'm thinking of using solder cups for connectors on the Slime, but I'm undecided on using solder cups or SMD (essentially just a gold pad) for connectors on the tools; the solder cups are more expensive by about £1.30 and could take up tool space, but be easier to solder, especially when 2 or more wires need to be soldered to a pin. I'm likely to choose solder cups for that reason, as well as consistency.
[E1][T] Motherboard on a moving axis?
07/01/2022 at 13:03 • 1 commentOk. Let's just assume some things. Let's assume that I can actually use the Manta M8P and OV4689 module without the expensive PCB "middleman", and swap out the 125 degree lens for either a 41 or 28 degree one, as seen below:
Then from my research, I might be able to use a ribbon cable length up to 1m in length, but the shorter the better. The max distance from the Tool Bar to the Slime is likely to exceed that distance, but from the Y axis slider it could be under 750mm. From the X axis slider, well it's probably short enough of a distance to not even need an extension.
If the M8P is on the X axis slider, the only semilong and long cables would be:
- Motors for Zmain, X, Y, Select, W
- Endstops for Zmain, Y
- 24V and 36V power
- Select servo signal wire
- Select RGB indicator signal wire, though that could be moved to the X axis and probably would be easier to see there instead of at the back on the Tool Bar
- Heated bed signal wires
- Heated bed thermistors
- USB to the other motherboard (M8P or OctPro)
It may also be easier to work on the electronics, as well as reducing the thickness of the Tool Bar, increasing the max tool depth. Additionally, having a nozzle cam permanently installed on both Slimes could be affordable and the camera data won't add traffic to the USB.
[E1] Just found out that the H616 doesn't have any MIPI-CSI at all, which is a shame. Even though a CM4 + OV4689 would've cost around about the same, apparently there's still a large stock backlog from last year. BananaPi's Banana Pi BPI-CM4 apparently wont show up on virtual shelves untill 22Q4 or 23Q1, but the chip it uses apparently can take up to 8MP @ 60fps. I can't tell if 60fps is a hard upper ceiling or it can be extrapolated somewhat based on bandwidth.
[M] Camera Mirror
06/30/2022 at 23:43 • 0 comments*Goes to Twitter to get link for CB1*
Achem. Anyway, so when I redesigned the Slight, the camera pcb was sticking out. Preferrably, I want the Slime fully enclosed so that I can pump cool air to components, like what Nasa has done (pg 10). I originally thought that I would use a mirror, but back when the Slime was a lot longer (just under 200mm compared to 106 now), I could just put the camera facing the nozzle without one.
It should be easier to move the mirror than the entire camera assembly. Also, as mentioned in the comment section of the previous log, I found a video on reducers, and I've decided on moving any motor reducer features to the arm holding the Slime (though, it looks more like a Snail now). If I assume that, if half of the SecSavr Spindle's weight is attached, the total mass of the Spindle, extruder motor and magnet is 1kg and the centre of mass is 5.3cm away from the pivot, I require 51.94Ncm of torque. Wait... is that right? Seems kind of low. I guess that's why my reduction was only 3.75:1 before. That simplifies things. I was thinking I was going to use the capstan drive [below], but a simple belt pulley should be enough. I can use some thick belt to mitigate elasticity in the joint.
I must be missing something though, because I found this listing for a 5 axis attachment and they've got higher reductions than 3:1 on motors that are likely at least 126Ncm.
[R] Worm gear for V axis?
06/30/2022 at 01:18 • 3 commentshttps://www.instructables.com/Strong-Worm-Gear-on-3d-Printer/
I just found this. I might not use it because it's a 20:1 and so could be quite slow (but if I can get 60rpm with decent acceleration, I wouldn't mind).
Currently, my plan is to have a curved GT2 rack and drive a closed belt.
Going cyclodial is probably the route out of this situation, but I thought the DIY worm gear looked cool so I wrote this log.
[M][P] Cheap glass found on Ebay
06/28/2022 at 15:32 • 0 commentsWhile looking at glass shelves for gd0105, I stumbled on some listings for cheap glass:
The long pane of glass was miles cheaper than the one I was thinking I was going to have to get for the 4 segment bed:
The square panes would also be much cheaper than the 300x400mm worktop savers I was planning to use for the 2 segment rotary bed. The last time I checked, which was months ago, the best I could find was 6 for £20. Seems that kind of deal is gone now, because I can only find £10 per each now.
These glass sizes weren't exactly the kinds of sizes I'd need, so I modelled them:
Glass Arrives
They came yesterday, together in a well sized box and it was a heavy one. I do wonder what kind of margins the sellers were actually making on this glass and I feel like it's just some sort of clearance.
Testing the glass backing
I rushed over to the 3D printers my university just happens to have and eventually installed it into the Ender3 V2.
The first thing I tried was a stringing test as I've also updated to Cura 5.0 now that the Materials Settings plugin has been updated. This PLA+ (never used this before) and printed with temps of 206/60 at a initial speed of 60mm/s.
