A vacuum fluorescent display (VFD) is a display device commonly used on consumer electronics equipment. VFD emits a very bright light with high contrast. Due to these features and the beautiful retro look, the devices made with these displays are very popular with do it yourself enthusiasts, but at the same time very complex in terms of connection and the way of communication with the microcontroller.
Another difficulty is the fact that in most cases they have almost no documentation and there are no libraries to simplify the code.
This time I will show you how to make a VU meter with 38 bars per channel on a 20x2 VFD display. It is very important to mention that in this project is used a VFD display of the type: "VFM202MDA", which contains PT6314 driver chip. This display with very little modification can be connected to the Arduino in the same way as the 16x2 Character LCD Display with the Hitachi HD44780 driver, which means that it uses the same libraries. Thus, with a very small change in the code that refers only to the number of displayed characters, almost any device based on the mentioned LCD display can be made on VFD.
![](https://cdn.hackaday.io/images/7823361646468602363.jpg)
The presented device is very simple to build, and consists of several components:
- Arduino nano microcontroller
- VFM202MDA1 type VFD Display (slightly modified)
- Stereo potentiometer
- and several resistors and capacitors
The modification of the VFD display consists in moving the short circuit from JP-7 to the JP-6 position. The picture below shows these places with a red circle, and also the communication pins that are compatible with the 16x2 LCD display.
![](https://cdn.hackaday.io/images/3152361646468643370.jpg)
![](https://cdn.hackaday.io/images/1711101646468652066.jpg)
![](https://cdn.hackaday.io/images/9613821646468662279.jpg)
The input consists of a stereo potentiometer to regulate the signal intensity. Next is the envelope follower with a filter. By changing the capacitance of the capacitor, the reaction speed of the VU meter also changes, specifically the return of each bar to its original position.
Finally, the device is built into a suitable housing made of PVC material with a thickness of 3 and 5 mm and coated with self-adhesive colored wallpaper.
![](https://cdn.hackaday.io/images/2704921646468692710.png)
This is cool. 👍 But where did you get your VFM202MDA1? When I do a search I can only find the Chinese manufacturer's website, nobody seems to sell one or three. Did you remove it from old equipment?
I see you're from Ohrid. Just by coincidence the other day I was reading about the geologic curiosities Lake Ohrid and Lake Prespa. It was the print version of this essay, truncated online due to paywall: https://granta.com/the-lake/
