BilaSens: from river to the cloud
A multisensor that send data via GSM to thingspeak and show them on a small screen
This project starts in 2020 during pandemic lockdown, after that it have loong periods of dust collecting.
Now is ready to start collect data and I want to share the code and the setup with the community!
Short story:
in the first version i've planned to record data on an SDcard as txt file and do not use any battery related precautions (a power bank that lasts some hours)
then the second version saves data on sd card + via Bluetooth Serial (android app) the data will be transmitted to a mobile phone and then parsed in excel
the latest version do not store data, but the readings are sent to thingspeak via a SIM800L module.
with a RTC (real time clock on pin 2 as interrupt) the device exit from deepsleep every 6 hours.
As power supply it uses two 18650 batteries with a small solar panel. To improve battery life on cloudy days now it works with a custom PCB with a standalone ATMEGA328p
As environmental guide I work on a river (canoeing) and the curiosity to know some river's parameters is obviously great!
This log is intended as self-learning work, if someone have some suggestion on my hobby-work  feel free to comment!
ATMEGA328p PCB with all sensor headers, and a UART port to communicate (FT232 adapter needed)
JPEG Image - 324.18 kB - 08/31/2022 at 13:01
Preview
  • 1 × arduino uno dfrobot clone
  • 1 × sim800l from aliexpress
  • 1 × 1nce SIM card 500mb for about 20€ no monthly fee
  • 1 × Logic level shifter from aliexpress
  • 1 × Transistor bigger then needed
View all 16 components
  • Drastic PCB improvements
    marcoA15210/04/2022 at 08:15 0 comments
    After (some) efforts trying to etch a custom PCB (see results), I've done a big step forward with custom PCB supplier PCBWay
    Let some pictures talk for me...
    Comparison: wich is the better?
    :-/   OK... My PCB it's like a MadMax DieselPunk nightmare... but anyway... it works!
    the packaging arrived\
    really a nice piece
    the progress
    with also a super interesting tracking production progress (with videos)
    that's all! now i have only to find a bit of time to link everything and start testing!
    see you soon!
  • working on a PCB
    marcoA15208/31/2022 at 12:59 0 comments
    NOW, next step is to produce a PCB, and I can show the work in progress: bottom side here, I will use presensitized board and... a lot of crossed fingers!
    pcb mask
    bottom layer, mirrored
    After etching shot (another mask) with some issues due to a washing process a bit too aggressive
    swimming time!
  • battery draining? no problem!
    marcoA15208/31/2022 at 12:49 0 comments
    with the described setup the project runs smoothly with the shiny summer sun, but with some cloudy days it starts do dry out the two 18650 batteries...
    So I've decided to remove the UNO board leaving only the ATMEGA328p controller, in a standalone setup.
    As a pseudo-test I've used a stripboard as soldering support
    So I can say it works! with a greatly reduced power consumption!
View all 3 project logs
  • 1
    The wiring
    Here a partial schematics of the sensor box:
    • all the power supplies wires (5V and GND) are not shown
    • the gray square on the right is a group of header pins: the "DF robots gravity series" sensors have a standard connector with 3 wires (5V, GND and data), I've passed the data line to Arduino thru a fourth pin (see image).
    To optimize battery consumption all the sensors are turned on/off thru a transistor controlled by "Sleep Pin HIGH/LOW".
    Instead of a voltage divider, I've used a logic level shifter to comunicate with the SIM800L (not 5V tolerant on RX pin and (maybe?) also on DTR. I've used it also in this case)
    After a lot of efforts, the only way to give the needed current to SIM800L (and avoiding undercharging or short circuits) is to use the direct battery output from the USP.
    I've used fat wires (for 220V!) for the connection, without them the current is too low and the SIM800L still blinking fast without registering on the net (rebooting after 7 blinks).
    RTC and OLED screen shares the same SDA&SCL but from two different places from the board.
    As Interrupt I've used Arduino pin 2 and SQW pin of the RTC (many guides about this online)
  • 2
    The code
    I will try to comment the code used for the sensor-box, this is the latest version consider that there's 6 version.
    The weirdest problem i've encountered is the heap fragmentation, as a self learning guy, I've wildly used Strings (especially in a past version where the time is taken from the GSM net), after this issues solved now the board run smoothly days and days.
    You can find the full code here
    In this first part there are the libraries and variables,
    the "SSD1306AsciiAvrI2c.h" for the OLED screen is the best for lower memory consumption.
    the variables are declared in this ugly way because... I've changed them a lot of time, experimenting
    the "RTClib.h" is the best I have found for timing and interrupt controlling
    /////////biladatalogger/////////
    ////sensors libs e co
    #include <SPI.h>
    #include <DallasTemperature.h>
    #include <OneWire.h>
    #define ONE_WIRE_BUS 6 //DS18S20 Signal pin on digital 6
    OneWire oneWire(ONE_WIRE_BUS);  // on digital pin 6
    DallasTemperature sensors(&oneWire);
    #include "GravityTDS.h"
    GravityTDS gravityTds;
    ////sim800
    #include <SoftwareSerial.h>
    SoftwareSerial gprsSerial(10, 3);//SIM800L Tx & Rx is connected to Arduino #10 #3
    const String THING_SPEAK_API_URL  = "GET https://api.thingspeak.com/update?api_key=XXXXXXXXXXXXXXXXXXXXXX";
    String request_url = "";
    /////clock
    #include "RTClib.h"     // DS3231 library
    #include <avr/sleep.h>  // AVR library for controlling the sleep modes
    /////screen
    //#include "SSD1306Ascii.h"
    #include "SSD1306AsciiAvrI2c.h"
    // 0X3C+SA0 - 0x3C or 0x3D
    #define I2C_ADDRESS 0x3C
    // Define proper RST_PIN if required.
    #define RST_PIN -1
    SSD1306AsciiAvrI2c oled;
    /////pHmeter
    #define Offset 1.00            //pH deviation compensate
    #define samplingInterval 30
    #define ArrayLenth  40    //times of collection
    #define ph_Pin A2            //pH meter Analog output to Arduino Analog Input 0
    ////sensors e mix stuff
    #define dtrPin 7
    #define sleepPin 8
    #define OledPin 9
    #define ECHOPIN 4// Pin to receive echo pulse
    #define TRIGPIN 5// Pin to send trigger pulse
    #define TdsSensorPin A1
    #define alarmPin 2 // The number of the pin for monitoring alarm status on DS3231
    /////variables
    int timer = 0;
    int  rtc_hour;
    RTC_DS3231 rtc;
    static String buff;
    const unsigned long timeout = 30000;
    String inData;
    String battData;
    String Buffer;
    int Volt;
    static float pHValue, voltage;
    float tdsValue = 0;
    int pHVal;
    int Dist;
    float Temperature = 0;
    float Temp_E = 0;
    float TurbVolt;
    int pHArray[ArrayLenth];   //Store the average value of the sensor feedback
    int pHArrayIndex = 0;
    void(* resetFunc) (void) = 0; //dichiarazione funzione reset
    The Setup
    See comments,
    the "pre-waking SIM800..." is for exiting from the sleepmode used for the GSMboard after a reset
    The sensors functions are in the next part.
    void setup() {
      Serial.begin(9600);
      gprsSerial.begin(9600);  //Begin serial communication with SIM800
      sensors.begin();
      pinMode(alarmPin, INPUT_PULLUP); // Set alarm pin as pullup
      pinMode(dtrPin, OUTPUT);    // sets the digital as output
      pinMode(sleepPin, OUTPUT);    // sets the digital as output
      pinMode(OledPin, OUTPUT);    // sets the digital as output
      pinMode(ECHOPIN, INPUT);
      pinMode(TRIGPIN, OUTPUT);
      pinMode(LED_BUILTIN, OUTPUT);
      digitalWrite(ECHOPIN, HIGH);
      digitalWrite(OledPin, HIGH);
      digitalWrite(sleepPin, HIGH);
      digitalWrite(dtrPin, LOW);
      gravityTds.setPin(TdsSensorPin);
      gravityTds.setAref(5.0);  //reference voltage on ADC, default 5.0V on Arduino UNO
      gravityTds.setAdcRange(1024);  //1024 for 10bit ADC;4096 for 12bit ADC
      gravityTds.begin();  //initialization
      if (! rtc.begin()) {
        Serial.println("Couldn't find RTC");
        Serial.flush();
        abort();
      // If required set time
      //rtc.adjust(DateTime(F(__DATE__), F(__TIME__))); // To compiled time
      //rtc.adjust(DateTime(2020, 7, 3, 20, 0, 0)); // Or explicitly, e.g. July 3, 2020 at 8pm
      // Disable and clear both alarms
      rtc.disableAlarm(1);
      rtc.disableAlarm(2);
      rtc.clearAlarm(1);
      rtc.clearAlarm(2);
      rtc.writeSqwPinMode(DS3231_OFF); // Place SQW pin into alarm interrupt mode
       rtc.disable32K();  //we don't need the 32K Pin, so disable it
      // print current time
      char date[10] = "hh:mm:ss";
      rtc.now().toString(date);
      Serial.println(date);
      delay(100);
    #if RST_PIN >= 0
      oled.begin(&Adafruit128x32, I2C_ADDRESS, RST_PIN);
    #else // RST_PIN >= 0
      oled.begin(&Adafruit128x32, I2C_ADDRESS);
    #endif // RST_PIN >= 0
      // Call oled.setI2cClock(frequency) to change from the default frequency.
      oled.setFont(Verdana12_bold);
      oled.clear();
      oled.set2X();
      oled.print("BilaSens6//l22");
      delay(1000);
      oled.clear();
      oled.print(date);
      Serial.print("pre-waking SIM800...");
      gprsSerial.println("AT");
      delay(1000);
      gprsSerial.println("AT+CSCLK=0");
      Serial.println("GET BATT SIM800...");
      waitForResponse();
      getBatteryLevel();
      ///////////////////////////////first rec in case of test/reboot
      Serial.println("BilaSens5//m22");
      Temp_E = rtc.getTemperature();
      delay(200);
      TempSens();
      delay(200);
      EchoDist();
      delay(200);
      TurbSens();
      delay(200);
      TDSSens();
      delay(200);
      phMeter();
      delay(200);
      Intvalmtr();
      digitalWrite(sleepPin, LOW);
      oleddrawchar();      // Draw characters of the default font
     // Gsm ();  //for test GSM on boot
     Sensors:
    On the board are present:
    • a waterproof echo distance measurement (50-400 cm +-2 cm)
    • a phmeter
    • a total dissolved solids TDS
    • thermometer
    • a turbidity sensor
    Intvalmtr() is for serial debug
    ////////EchoDist/////////
    void EchoDist() {
      digitalWrite(TRIGPIN, LOW); // Set the trigger pin to low for 2uS
      delayMicroseconds(2);
      digitalWrite(TRIGPIN, HIGH); // Send a 10uS high to trigger ranging
      delayMicroseconds(10);
      digitalWrite(TRIGPIN, LOW); // Send pin low again
      double Dist1 = pulseIn(ECHOPIN, HIGH);
      Dist1 = Dist1  * 0.034 / 2;
      delay(50);// Wait 50mS before next ranging
      if (Dist1 == 0) {
        EchoDist();
      else {
        Dist = Dist1;
    /////////phMeter/////////
    void phMeter()
      const int numReadings = 40;       // smooth the result
      float total = 0;                  // the running total
      float average = 0;                // the average
      for (int thisReading = 0; thisReading < numReadings; thisReading++) {
        total += analogRead(ph_Pin);
        delay(20);
      average = (total / numReadings);
      voltage = average * 5.0 / 1024;
      pHValue = 3.5 * voltage + Offset;
    /////////TDSSens/////////
    void TDSSens() {
      gravityTds.setTemperature(Temperature);  // set the temperature and execute temperature compensation
      gravityTds.update();  //sample and calculate
      tdsValue = gravityTds.getTdsValue();  // then get the value
    /////////TempSens/////////
    void TempSens() {
      sensors.requestTemperatures();
      Temperature = sensors.getTempCByIndex(0);
    /////////TurbSens/////////
    void TurbSens() {
      int turbValue = analogRead(A0);// read the input on analog pin 0:
      TurbVolt = turbValue * (5.0 / 1024.0); // Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V):
    void Intvalmtr() {
      Serial.print("Dist: ");
      Serial.print(Dist);
      Serial.print("   cm");
      Serial.print(", TurbV: ");
      Serial.print(TurbVolt);
      Serial.print("   V");
      Serial.print(", Temp: ");
      Serial.print(Temperature);
      Serial.print("   C");
      Serial.print(", Temp_E: ");
      Serial.print(Temp_E);
      Serial.print("   C");
      Serial.print(", pH: ");
      Serial.print(pHValue);
      Serial.print(", TDS: ");
      Serial.print(tdsValue);
      Serial.print(" ppm");
      Serial.print(", batt: ");
      Serial.print(Volt);
      Serial.println(" mV");
      delay(1000);
     The Oled screen, print stuff from sensors
    //////OLEDdisp//////
    void oleddrawchar(void) {
      oled.setFont(Adafruit5x7);
      oled.set1X();
      oled.clear();
      oled.print("ph:");
      oled.println(pHValue);
      oled.print("temp:");
      oled.print(Temperature);
      oled.println("C");
      oled.print("tds:");
      oled.print(tdsValue);
      oled.println("ppm");
      oled.print("dist:");
      oled.print(Dist);
      oled.print("cm ");
      oled.print(Volt);
      oled.print("mV");
      delay(6000);
    Here all the stuff related to SIM800L, the waitForResponse() and ShowSerialData()
    functions are not very elegant but they works.
    request_url.concat is a good choice to prevent working with Strings in other ways? anyway it works without doing this!!
    from adafruit
    The first part is from this blog
    If the gprs.serial do not responds, in wait() function, (too low current from batteries) the device go to sleep for 6 hours, and maybe can get a bit of sun from the 5V solar panel
    The last part getBatteryLevel() is thruly a cool function to get voltage from 18650 batteries!
    Volt = battData.substring(20, 24).toInt(); is the only way I have found to get the wanted value as Int
    /////////////////////////////// GSM transmission and string concat
    void Gsm () {
      // stopSLeep
      delay(1000);
      Serial.println("waking SIM800...");
      waitForResponse();
      getBatteryLevel();
      request_url = THING_SPEAK_API_URL;
      request_url.concat("&field1=");
      request_url.concat(Dist);
      request_url.concat("&field2=");
      request_url.concat(TurbVolt);
      request_url.concat("&field3=");
      request_url.concat(Temperature);
      request_url.concat("&field4=");
      request_url.concat(pHValue);
      request_url.concat("&field5=");
      request_url.concat(tdsValue);
      request_url.concat("&field6=");
      request_url.concat(Volt);
      request_url.concat("&field7=");
      request_url.concat(Temp_E);
      waitForResponse();
      gprsSerial.println("AT+CPIN?");
      waitForResponse();
      gprsSerial.println("AT+CREG?");
      waitForResponse();
      gprsSerial.println("AT+CGATT?");
      waitForResponse();
      gprsSerial.println("AT+CSQ"); //Signal quality test, value range is 0-31 , 31 is the best
      waitForResponse();
      gprsSerial.println("AT+CIPSHUT");
      waitForResponse();
      gprsSerial.println("AT+CIPSTATUS");
      waitForResponse();
      gprsSerial.println("AT+CIPMUX=0");
      waitForResponse();
      gprsSerial.println("AT+CSTT=\"iot.1nce.net\"");//start task and setting the APN,
      waitForResponse();
      gprsSerial.println("AT+CIICR");//bring up wireless connection
      waitForResponse();
      gprsSerial.println("AT+CIFSR");//get local IP adress
      ShowSerialData();
      delay(3000);
      gprsSerial.println("AT+CIPSPRT=0");
      delay(3000);
      ShowSerialData();
      gprsSerial.println("AT+CIPSTART=\"TCP\",\"api.thingspeak.com\",\"80\"");//start up the connection
      delay(6000);
      ShowSerialData();
      gprsSerial.println("AT+CIPSEND");//begin send data to remote server
      delay(4000);
      ShowSerialData();
      gprsSerial.println(request_url);//begin send data to remote server
      delay(4000);
      ShowSerialData();
      gprsSerial.println((char)26);//sending
      delay(5000);//waitting for reply, important! the time is base on the condition of internet
      gprsSerial.println();
      ShowSerialData();
      gprsSerial.println("AT+CIPSHUT");//close the connection
      delay(100);
      ShowSerialData();
      // start SLeep
      //  gprsSerial.println("AT + CFUN = 0");
      //  ShowSerialData();
      digitalWrite(dtrPin, HIGH);
      delay(50);
      gprsSerial.println("AT+CSCLK=2");
      waitForResponse();
      delay(5000);
    ///////////////////////////////end transmission
    /////////////////////////////// GSM related stuff
    void ShowSerialData()
      while (gprsSerial.available() != 0)
        Serial.write(gprsSerial.read());
      //  oled.clear();
      //  oled.println(gprsSerial.read());
      delay(500);
    static void waitForResponse() {
      if (wait()) {
        buff = gprsSerial.readString();
        Serial.print(buff);
        //    oled.clear();
        //    oled.print(buff);
      else {
        buff = "";
    static boolean wait()
      unsigned long start = millis();
      unsigned long delta = 0;
      while (!gprsSerial.available()) {
        delta = millis() - start;
        if (delta >= timeout) {
          Serial.println("no risp!");
          oled.set1X();
          oled.clear();
          oled.print("wait for solar batt charge ");
          delay(2000);
          oled.ssd1306WriteCmd(SSD1306_DISPLAYOFF); // To switch display off
          //go to sleep 6 hour
          sleep_enable();                       // Enabling sleep mode
          set_sleep_mode(SLEEP_MODE_PWR_DOWN);  // Setting the sleep mode, in this case full sleep
          noInterrupts();                       // Disable interrupts
          attachInterrupt(digitalPinToInterrupt(alarmPin), alarm_ISR, LOW);
          Serial.println("Going to sleep!");    // Print message to serial monitor
          Serial.flush();                       // Ensure all characters are sent to the serial monitor
          interrupts();                         // Allow interrupts again
          sleep_cpu();                          // Enter sleep mode
          /* The program will continue from here when it wakes */
          // Disable and clear alarm
          // rtc.disableAlarm(1);
          rtc.clearAlarm(1);
          Serial.println("I'm back!");          // Print message to show we're back
          break;
      return gprsSerial.available();
    void getBatteryLevel() {
      Volt = 0;
      battData = "";
      gprsSerial.println("AT+CBC"); // battery level
      delay(500);
      while (gprsSerial.available()) {
        battData += char(gprsSerial.read());
      delay(500);
    One of the most important parts for preserve battery power, heavily commented
    void enterSleep() {
      //sleep
      digitalWrite(LED_BUILTIN, LOW);
      //digitalWrite(OledPin, LOW);
      // GSM
      Serial.print("preparing sleep SIM800...");
      delay(1000);
      waitForResponse();
      delay(10);
      waitForResponse();
      delay(1000);
      //cpu
      //rtc.disableAlarm(1);
      rtc.clearAlarm(1);
    void alarm_ISR() {
      // This runs when SQW pin is low. It will wake up the µController
      sleep_disable(); // Disable sleep mode
      detachInterrupt(digitalPinToInterrupt(alarmPin)); // Detach the interrupt to stop it firing
    Dulcis in fundo, the main loop
    On first boot (timer=0) it checks in wich part of the day we are, then go to sleep until designed time.
    then set the alarm 6 hour later, do the readings, send them to thingspeak and go to sleep again
    void loop() {
      DateTime now = rtc.now();  // Get current time
      if (timer == 1) {
        rtc.setAlarm1(rtc.now() + TimeSpan(0, 6, 0, 0), DS3231_A1_Hour);
        //rtc.setAlarm1(rtc.now() + TimeSpan(0, 0, 0, 0), DS3231_A1_Minute);
        //rtc.setAlarm1(rtc.now() + TimeSpan(59), DS3231_A1_Second);
        delay(4000);
        delay(200);
        TempSens();
        delay(200);
        EchoDist();
        delay(200);
        TurbSens();
        delay(200);
        TDSSens();
        delay(200);
        phMeter();
        delay(200);
        //    Intvalmtr();
        Gsm();
        enterSleep();  // Go to sleep
      if (timer == 0) {
        rtc_hour =  now.hour();
        Serial.println("rtc_hour from rtc");
        Serial.println(rtc_hour);
        oled.set1X();
        oled.clear();
        if (rtc_hour < 12) {
          rtc.setAlarm1(DateTime(0, 0, 0, 12, 0, 0), DS3231_A1_Hour); // Set first alarm
          timer = 1;
          oled.print("next alarm: 12");
          delay(2000);
          enterSleep();
        if (rtc_hour > 12 && rtc_hour < 18) {
          rtc.setAlarm1(DateTime(0, 0, 0, 18, 0, 0), DS3231_A1_Hour); // Set first alarm
          oled.print("next alarm: 18");
          delay(2000);
          timer = 1;
          enterSleep();
        if (rtc_hour > 18) {
          rtc.setAlarm1(DateTime(0, 0, 0, 0, 0, 0), DS3231_A1_Hour); // Set first alarm
          oled.print("next alarm: 00");
          delay(2000);
          timer = 1;
          enterSleep();
  • 3
    The testing setup
    This is the working test setup in a small artificial pondfrom another view
    under the boat
    the turbidity sensor in NOT... waterproof! why? a big work of self-amalgamating tape and silicone glue is needed to do not wet the circuits…
    The "Splash screen"
    What time is it now?
    The readings on screen
    Next alarm (gsm sending) at...
    Here you can see collected data "realtime"
    at now, 31 july 22)
View all 4 instructions
Rich text editor
