If you make this seriously, it is quite troublesome to build a voice coil drive circuit with a power op-amp whose output current is about 100mA, make a circuit to read the PDIC output signal with an ADC, write microcontroller software, and so on.
Therefore, I designed it with the theme of "Let’s push all the troublesome things to Analog Discovery 2".
kuriuzu
Sky Carter
LesWright
iliasam
Oi. Gostaria de fazer esse projeto. Mas não entendo muito de script.
Voce poderia colocar mais detalhes da construção e programação no Analog discovery 2, se possivel com video no youtube .
