Interface for the potentiostat
3D-printed Interface to connect pinout of potentiostat to screen-printed electrodes
0 followers
An interface is constructed using 3D printing and a simple PCB. Which can be used to connect the screen-printed electrode to the pin of a potentiostat. Usually, crocodile pins are connected to the screen-printed electrode, which makes it clumsy and difficult to operate (for example: performing cyclic voltammetry). A simple and easy to construct interface is proposed which can be a one-time and less time-consuming investment for a researcher.
bottom plate of 3D printed case.stl
A bottom plate is attached to the PCB for support
Standard Tesselated Geometry - 511.60 kB - 03/28/2022 at 18:53
Download
upper plate of 3D printed case.stl
An upper plate is attached to the PCB for support
Standard Tesselated Geometry - 356.82 kB - 03/28/2022 at 18:53
Download
Dimension of PCB.pdf
The PCB is used in single-sided PCB. The tracks on the PCB are made using CNC machines and the gerber file "PCB gerber" is accessible in this file section
Adobe Portable Document Format - 3.53 kB - 03/28/2022 at 18:53
Preview
PCB gerber - CADCAM.ZIP
x-zip-compressed - 8.80 kB - 03/28/2022 at 18:53
Download
3D view of the PCB.pdf
3D view of PCB for better understanding of the finished PCB. The banana pinhead (plug) is cut and the back portion of the pin is soldered to the PCB.
Preview
Rich text editor
