Trying it out on pegboards!
06/04/2022 at 22:46 • 0 commentsI tried it out with pegboards, and it worked great! Simply weave the el wire through the holes in the pegboard and create simple shapes.
Then turn off the lights and turn on the EL wire.
Thinner EL wire works better, you can fit more through each hole that way. -
Trying out thinner el wire...
04/13/2022 at 03:53 • 0 commentsOrdered up some 1.4 mm el wire, somewhere I read that thinner el wire has a tighter bend radius. It was a bit better but still not as tight as I would like... Going to have to think a bit more on what to try next.
