Airfoil Design with OpenSCAD
04/30/2022 at 02:41 • 0 commentshull(){ for(z = [0:10:1000]){ translate([0,0,z]){ rotate([0,0,45*z/1000]){ linear_extrude(0.1){ scale([thicknessArray[z],thicknessArray[z]]){ projection(cut = true){ translate([0,0,-z]){ hull(){ //base(); translate([0,0,0]){ nrel_s835(); }; translate([0,0,300]){ nrel_s835(); }; translate([0,0,750]){ nrel_s833(); } translate([0,0,950]){ nrel_s834(); } translate([0,0,1000]){ nrel_s834(); } } } } } } } } } } module base(){ linear_extrude(0.1){ scale([1/800, 1/800]){ circle(400); } } } module nrel_s835(){ linear_extrude(0.1){ translate([-0.305,0]){ polygon(points=[[1.000000, 0.000000], [0.995932, 0.000974], [0.984473, 0.004552], [0.967194, 0.010971], [0.945459, 0.019503], [0.919943, 0.029016], [0.890618, 0.038526], [0.857149, 0.047861], [0.819938, 0.057178], [0.779531, 0.066312], [0.736444, 0.075033], [0.691173, 0.083101], [0.644202, 0.090280], [0.596002, 0.096359], [0.547033, 0.101147], [0.497745, 0.104476], [0.448511, 0.106196], [0.399664, 0.106378], [0.351783, 0.104999], [0.305188, 0.102105], [0.260367, 0.097834], [0.217816, 0.092265], [0.177969, 0.085485], [0.141266, 0.077587], [0.108053, 0.068680], [0.078706, 0.058894], [0.053467, 0.048379], [0.032658, 0.037351], [0.016487, 0.026032], [0.005368, 0.014774], [0.003569, 0.012203], [0.001995, 0.009465], [0.000868, 0.006772], [0.000259, 0.003974], [0.000230, 0.003763], [0.000015, 0.000995], [0.001113, -0.008866], [0.006381, -0.022529], [0.015773, -0.036575], [0.029084, -0.050332], [0.046306, -0.063467], [0.067214, -0.075502], [0.091816, -0.086196], [0.119820, -0.095194], [0.151207, -0.102304], [0.185631, -0.107229], [0.223218, -0.109799], [0.263720, -0.110144], [0.306838, -0.108293], [0.352267, -0.104298], [0.399699, -0.098265], [0.448814, -0.090357], [0.499275, -0.080810], [0.550725, -0.069931], [0.602768, -0.058110], [0.654962, -0.045821], [0.706793, -0.033614], [0.757643, -0.022112], [0.806764, -0.011986], [0.853241, -0.003934], [0.895818, 0.001265], [0.932596, 0.003434], [0.962014, 0.003325], [0.983186, 0.002036], [0.995825, 0.000638]], convexity = 10); } } } module nrel_s833(){ linear_extrude(0.1){ translate([-0.363,0]){ polygon(points=[[1.000000, 0.000000], [0.996065, 0.001004], [0.985020, 0.004646], [0.968439, 0.011090], [0.947640, 0.019540], [0.923225, 0.028827], [0.895095, 0.037957], [0.862843, 0.046779], [0.826835, 0.055487], [0.787593, 0.063938], [0.745618, 0.071919], [0.701398, 0.079186], [0.655387, 0.085456], [0.607899, 0.090488], [0.559249, 0.094305], [0.510051, 0.096851], [0.460675, 0.097982], [0.411514, 0.097776], [0.363095, 0.096316], [0.315946, 0.093639], [0.270564, 0.089788], [0.227440, 0.084804], [0.187003, 0.078746], [0.149688, 0.071682], [0.115830, 0.063700], [0.085796, 0.054909], [0.059807, 0.045441], [0.038158, 0.035491], [0.021003, 0.025264], [0.008633, 0.015086], [0.001918, 0.006451], [0.001336, 0.005330], [0.000805, 0.004131], [0.000137, 0.001900], [0.000005, -0.000388], [0.000267, -0.002838], [0.000510, -0.004055], [0.005161, -0.014877], [0.014227, -0.026119], [0.027615, -0.037318], [0.045093, -0.047937], [0.066696, -0.057725], [0.092161, -0.066350], [0.121486, -0.073652], [0.154343, -0.079439], [0.190655, -0.083625], [0.230021, -0.086135], [0.272278, -0.086956], [0.316953, -0.086108], [0.363791, -0.083647], [0.412249, -0.079666], [0.461977, -0.074263], [0.512361, -0.067552], [0.563000, -0.059518], [0.613510, -0.050246], [0.663842, -0.039707], [0.713990, -0.028763], [0.763368, -0.018233], [0.811239, -0.008893], [0.856691, -0.001519], [0.898436, 0.003017], [0.934459, 0.004533], [0.963162, 0.003879], [0.983725, 0.002236], [0.995960, 0.000675]], convexity = 10); } } } module nrel_s834(){ linear_extrude(0.1){ translate([-0.395,0]){ polygon(points=[[1.000000, 0.000000], [0.996064, 0.000606], [0.984816, 0.003101], [0.967539, 0.007914], [0.945483, 0.014649], [0.919407, 0.022470], [0.889501, 0.030561], [0.855652, 0.038699], [0.818293, 0.046926], [0.777966, 0.055030], [0.735169, 0.062727], [0.690338, 0.069726], [0.643856, 0.075777], [0.596064, 0.080708], [0.547330, 0.084531], [0.498288, 0.087141], [0.449272, 0.088341], [0.400592, 0.088199], [0.352742, 0.086855], [0.306248, 0.084371], [0.261604, 0.080802], [0.219296, 0.076196], [0.179743, 0.070615], [0.143372, 0.064126], [0.110502, 0.056817], [0.081485, 0.048795], [0.056518, 0.040187], [0.035873, 0.031189], [0.019660, 0.022005], [0.008118, 0.012967], [0.001394, 0.004469], [0.001039, 0.003754], [0.000308, 0.001855], [0.000001, 0.000091], [0.000250, -0.001671], [0.000632, -0.002862], [0.000915, -0.003559], [0.006099, -0.010998], [0.016371, -0.019451], [0.031347, -0.027791], [0.050767, -0.035619], [0.074629, -0.042738], [0.102659, -0.048948], [0.134765, -0.054145], [0.170598, -0.058239], [0.209956, -0.061194], [0.252411, -0.062996], [0.297656, -0.063666], [0.345187, -0.063248], [0.394605, -0.061807], [0.445343, -0.059431], [0.496925, -0.056213], [0.548737, -0.052268], [0.600249, -0.047696], [0.650829, -0.042590], [0.699974, -0.037023], [0.747128, -0.031105], [0.791833, -0.024939], [0.833594, -0.018671], [0.872254, -0.012170], [0.907866, -0.006512], [0.939211, -0.002526], [0.965020, -0.000329], [0.984215, 0.000393], [0.996021, 0.000244]], convexity = 10); } } } rotationArray = [0, 0.09, 0.18, 0.27, 0.36, 0.44999999999999996, 0.5399999999999999, 0.6299999999999999, 0.7199999999999999, 0.8099999999999998, 0.8999999999999998, 0.9899999999999998, 1.0799999999999998, 1.17, 1.26, 1.35, 1.4400000000000002, 1.5300000000000002, 1.6200000000000003, 1.7100000000000004, 1.8000000000000005, 1.8900000000000006, 1.9800000000000006, 2.0700000000000007, 2.1600000000000006, 2.2500000000000004, 2.3400000000000003, 2.43, 2.52, 2.61, 2.6999999999999997, 2.7899999999999996, 2.8799999999999994, 2.9699999999999993, 3.059999999999999, 3.149999999999999, 3.239999999999999, 3.3299999999999987, 3.4199999999999986, 3.5099999999999985, 3.5999999999999983, 3.689999999999998, 3.779999999999998, 3.869999999999998, 3.9599999999999977, 4.049999999999998, 4.139999999999998, 4.229999999999998, 4.319999999999998, 4.4099999999999975, 4.499999999999997, 4.589999999999997, 4.679999999999997, 4.769999999999997, 4.859999999999997, 4.949999999999997, 5.0399999999999965, 5.129999999999996, 5.219999999999996, 5.309999999999996, 5.399999999999996, 5.489999999999996, 5.579999999999996, 5.6699999999999955, 5.759999999999995, 5.849999999999995, 5.939999999999995, 6.029999999999995, 6.119999999999995, 6.209999999999995, 6.2999999999999945, 6.389999999999994, 6.479999999999994, 6.569999999999994, 6.659999999999994, 6.749999999999994, 6.839999999999994, 6.9299999999999935, 7.019999999999993, 7.109999999999993, 7.199999999999993, 7.289999999999993, 7.379999999999993, 7.469999999999993, 7.5599999999999925, 7.649999999999992, 7.739999999999992, 7.829999999999992, 7.919999999999992, 8.009999999999993, 8.099999999999993, 8.189999999999992, 8.279999999999992, 8.369999999999992, 8.459999999999992, 8.549999999999992, 8.639999999999992, 8.729999999999992, 8.819999999999991, 8.909999999999991, 8.999999999999991, 9.089999999999991, 9.17999999999999, 9.26999999999999, 9.35999999999999, 9.44999999999999, 9.53999999999999, 9.62999999999999, 9.71999999999999, 9.80999999999999, 9.89999999999999, 9.98999999999999, 10.07999999999999, 10.16999999999999, 10.25999999999999, 10.349999999999989, 10.439999999999989, 10.529999999999989, 10.619999999999989, 10.709999999999988, 10.799999999999988, 10.889999999999988, 10.979999999999988, 11.069999999999988, 11.159999999999988, 11.249999999999988, 11.339999999999987, 11.429999999999987, 11.519999999999987, 11.609999999999987, 11.699999999999987, 11.789999999999987, 11.879999999999987, 11.969999999999986, 12.059999999999986, 12.149999999999986, 12.239999999999986, 12.329999999999986, 12.419999999999986, 12.509999999999986, 12.599999999999985, 12.689999999999985, 12.779999999999985, 12.869999999999985, 12.959999999999985, 13.049999999999985, 13.139999999999985, 13.229999999999984, 13.319999999999984, 13.409999999999984, 13.499999999999984, 13.589999999999984, 13.679999999999984, 13.769999999999984, 13.859999999999983, 13.949999999999983, 14.039999999999983, 14.129999999999983, 14.219999999999983, 14.309999999999983, 14.399999999999983, 14.489999999999982, 14.579999999999982, 14.669999999999982, 14.759999999999982, 14.849999999999982, 14.939999999999982, 15.029999999999982, 15.119999999999981, 15.209999999999981, 15.299999999999981, 15.389999999999981, 15.47999999999998, 15.56999999999998, 15.65999999999998, 15.74999999999998, 15.83999999999998, 15.92999999999998, 16.019999999999982, 16.10999999999998, 16.19999999999998, 16.28999999999998, 16.37999999999998, 16.46999999999998, 16.55999999999998, 16.64999999999998, 16.73999999999998, 16.82999999999998, 16.91999999999998, 17.00999999999998, 17.09999999999998, 17.18999999999998, 17.27999999999998, 17.36999999999998, 17.45999999999998, 17.54999999999998, 17.63999999999998, 17.72999999999998, 17.81999999999998, 17.90999999999998, 17.99999999999998, 18.08999999999998, 18.17999999999998, 18.26999999999998, 18.359999999999978, 18.449999999999978, 18.539999999999978, 18.629999999999978, 18.719999999999978, 18.809999999999977, 18.899999999999977, 18.989999999999977, 19.079999999999977, 19.169999999999977, 19.259999999999977, 19.349999999999977, 19.439999999999976, 19.529999999999976, 19.619999999999976, 19.709999999999976, 19.799999999999976, 19.889999999999976, 19.979999999999976, 20.069999999999975, 20.159999999999975, 20.249999999999975, 20.339999999999975, 20.429999999999975, 20.519999999999975, 20.609999999999975, 20.699999999999974, 20.789999999999974, 20.879999999999974, 20.969999999999974, 21.059999999999974, 21.149999999999974, 21.239999999999974, 21.329999999999973, 21.419999999999973, 21.509999999999973, 21.599999999999973, 21.689999999999973, 21.779999999999973, 21.869999999999973, 21.959999999999972, 22.049999999999972, 22.139999999999972, 22.229999999999972, 22.319999999999972, 22.40999999999997, 22.49999999999997, 22.58999999999997, 22.67999999999997, 22.76999999999997, 22.85999999999997, 22.94999999999997, 23.03999999999997, 23.12999999999997, 23.21999999999997, 23.30999999999997, 23.39999999999997, 23.48999999999997, 23.57999999999997, 23.66999999999997, 23.75999999999997, 23.84999999999997, 23.93999999999997, 24.02999999999997, 24.11999999999997, 24.20999999999997, 24.29999999999997, 24.38999999999997, 24.47999999999997, 24.56999999999997, 24.659999999999968, 24.749999999999968, 24.839999999999968, 24.929999999999968, 25.019999999999968, 25.109999999999967, 25.199999999999967, 25.289999999999967, 25.379999999999967, 25.469999999999967, 25.559999999999967, 25.649999999999967, 25.739999999999966, 25.829999999999966, 25.919999999999966, 26.009999999999966, 26.099999999999966, 26.189999999999966, 26.279999999999966, 26.369999999999965, 26.459999999999965, 26.549999999999965, 26.639999999999965, 26.729999999999965, 26.819999999999965, 26.909999999999965, 26.999999999999964, 27.089999999999964, 27.179999999999964, 27.269999999999964, 27.359999999999964, 27.449999999999964, 27.539999999999964, 27.629999999999963, 27.719999999999963, 27.809999999999963, 27.899999999999963, 27.989999999999963, 28.079999999999963, 28.169999999999963, 28.259999999999962, 28.349999999999962, 28.439999999999962, 28.529999999999962, 28.619999999999962, 28.70999999999996, 28.79999999999996, 28.88999999999996, 28.97999999999996, 29.06999999999996, 29.15999999999996, 29.24999999999996, 29.33999999999996, 29.42999999999996, 29.51999999999996, 29.60999999999996, 29.69999999999996, 29.78999999999996, 29.87999999999996, 29.96999999999996, 30.05999999999996, 30.14999999999996, 30.23999999999996, 30.32999999999996, 30.41999999999996, 30.50999999999996, 30.59999999999996, 30.68999999999996, 30.77999999999996, 30.86999999999996, 30.959999999999958, 31.049999999999958, 31.139999999999958, 31.229999999999958, 31.319999999999958, 31.409999999999958, 31.499999999999957, 31.589999999999957, 31.679999999999957, 31.769999999999957, 31.859999999999957, 31.949999999999957, 32.03999999999996, 32.12999999999996, 32.21999999999996, 32.30999999999997, 32.39999999999997, 32.489999999999974, 32.57999999999998, 32.66999999999998, 32.759999999999984, 32.84999999999999, 32.93999999999999, 33.029999999999994, 33.12, 33.21, 33.300000000000004, 33.39000000000001, 33.48000000000001, 33.570000000000014, 33.66000000000002, 33.75000000000002, 33.840000000000025, 33.93000000000003, 34.02000000000003, 34.110000000000035, 34.20000000000004, 34.29000000000004, 34.380000000000045, 34.47000000000005, 34.56000000000005, 34.650000000000055, 34.74000000000006, 34.83000000000006, 34.920000000000066, 35.01000000000007, 35.10000000000007, 35.190000000000076, 35.28000000000008, 35.37000000000008, 35.460000000000086, 35.55000000000009, 35.64000000000009, 35.730000000000096, 35.8200000000001, 35.9100000000001, 36.00000000000011, 36.09000000000011, 36.18000000000011, 36.27000000000012, 36.36000000000012, 36.450000000000124, 36.54000000000013, 36.63000000000013, 36.720000000000134, 36.81000000000014, 36.90000000000014, 36.990000000000144, 37.08000000000015, 37.17000000000015, 37.260000000000154, 37.35000000000016, 37.44000000000016, 37.530000000000165, 37.62000000000017, 37.71000000000017, 37.800000000000175, 37.89000000000018, 37.98000000000018, 38.070000000000185, 38.16000000000019, 38.25000000000019, 38.340000000000195, 38.4300000000002, 38.5200000000002, 38.610000000000205, 38.70000000000021, 38.79000000000021, 38.880000000000216, 38.97000000000022, 39.06000000000022, 39.150000000000226, 39.24000000000023, 39.33000000000023, 39.420000000000236, 39.51000000000024, 39.60000000000024, 39.690000000000246, 39.78000000000025, 39.87000000000025, 39.96000000000026, 40.05000000000026, 40.14000000000026, 40.23000000000027, 40.32000000000027, 40.410000000000274, 40.50000000000028, 40.59000000000028, 40.680000000000284, 40.77000000000029, 40.86000000000029, 40.950000000000294, 41.0400000000003, 41.1300000000003, 41.220000000000304, 41.31000000000031, 41.40000000000031, 41.490000000000315, 41.58000000000032, 41.67000000000032, 41.760000000000325, 41.85000000000033, 41.94000000000033, 42.030000000000335, 42.12000000000034, 42.21000000000034, 42.300000000000345, 42.39000000000035, 42.48000000000035, 42.570000000000356, 42.66000000000036, 42.75000000000036, 42.840000000000366, 42.93000000000037, 43.02000000000037, 43.110000000000376, 43.20000000000038, 43.29000000000038, 43.380000000000386, 43.47000000000039, 43.56000000000039, 43.6500000000004, 43.7400000000004, 43.8300000000004, 43.92000000000041, 44.01000000000041, 44.10000000000041, 44.19000000000042, 44.28000000000042, 44.370000000000424, 44.46000000000043, 44.55000000000043, 44.640000000000434, 44.73000000000044, 44.82000000000044, 44.910000000000444, 45.00000000000045, 45.09000000000045, 45.180000000000454, 45.27000000000046, 45.36000000000046, 45.450000000000465, 45.54000000000047, 45.63000000000047, 45.720000000000475, 45.81000000000048, 45.90000000000048, 45.990000000000485, 46.08000000000049, 46.17000000000049, 46.260000000000495, 46.3500000000005, 46.4400000000005, 46.530000000000506, 46.62000000000051, 46.71000000000051, 46.800000000000516, 46.89000000000052, 46.98000000000052, 47.070000000000526, 47.16000000000053, 47.25000000000053, 47.340000000000536, 47.43000000000054, 47.52000000000054, 47.61000000000055, 47.70000000000055, 47.79000000000055, 47.88000000000056, 47.97000000000056, 48.060000000000564, 48.15000000000057, 48.24000000000057, 48.330000000000574, 48.42000000000058, 48.51000000000058, 48.600000000000584, 48.69000000000059, 48.78000000000059, 48.870000000000594, 48.9600000000006, 49.0500000000006, 49.140000000000605, 49.23000000000061, 49.32000000000061, 49.410000000000615, 49.50000000000062, 49.59000000000062, 49.680000000000625, 49.77000000000063, 49.86000000000063, 49.950000000000635, 50.04000000000064, 50.13000000000064, 50.220000000000645, 50.31000000000065, 50.40000000000065, 50.490000000000656, 50.58000000000066, 50.67000000000066, 50.760000000000666, 50.85000000000067, 50.94000000000067, 51.030000000000676, 51.12000000000068, 51.21000000000068, 51.300000000000686, 51.39000000000069, 51.48000000000069, 51.5700000000007, 51.6600000000007, 51.7500000000007, 51.84000000000071, 51.93000000000071, 52.020000000000714, 52.11000000000072, 52.20000000000072, 52.290000000000724, 52.38000000000073, 52.47000000000073, 52.560000000000734, 52.65000000000074, 52.74000000000074, 52.830000000000744, 52.92000000000075, 53.01000000000075, 53.100000000000755, 53.19000000000076, 53.28000000000076, 53.370000000000765, 53.46000000000077, 53.55000000000077, 53.640000000000775, 53.73000000000078, 53.82000000000078, 53.910000000000785, 54.00000000000079, 54.09000000000079, 54.180000000000796, 54.2700000000008, 54.3600000000008, 54.450000000000806, 54.54000000000081, 54.63000000000081, 54.720000000000816, 54.81000000000082, 54.90000000000082, 54.990000000000826, 55.08000000000083, 55.17000000000083, 55.26000000000084, 55.35000000000084, 55.44000000000084, 55.53000000000085, 55.62000000000085, 55.71000000000085, 55.80000000000086, 55.89000000000086, 55.980000000000864, 56.07000000000087, 56.16000000000087, 56.250000000000874, 56.34000000000088, 56.43000000000088, 56.520000000000884, 56.61000000000089, 56.70000000000089, 56.790000000000894, 56.8800000000009, 56.9700000000009, 57.060000000000905, 57.15000000000091, 57.24000000000091, 57.330000000000915, 57.42000000000092, 57.51000000000092, 57.600000000000925, 57.69000000000093, 57.78000000000093, 57.870000000000935, 57.96000000000094, 58.05000000000094, 58.140000000000946, 58.23000000000095, 58.32000000000095, 58.410000000000956, 58.50000000000096, 58.59000000000096, 58.680000000000966, 58.77000000000097, 58.86000000000097, 58.950000000000976, 59.04000000000098, 59.13000000000098, 59.22000000000099, 59.31000000000099, 59.40000000000099, 59.490000000001, 59.580000000001, 59.670000000001004, 59.76000000000101, 59.85000000000101, 59.940000000001014, 60.03000000000102, 60.12000000000102, 60.210000000001024, 60.30000000000103, 60.39000000000103, 60.480000000001034, 60.57000000000104, 60.66000000000104, 60.750000000001044, 60.84000000000105, 60.93000000000105, 61.020000000001055, 61.11000000000106, 61.20000000000106, 61.290000000001065, 61.38000000000107, 61.47000000000107, 61.560000000001075, 61.65000000000108, 61.74000000000108, 61.830000000001085, 61.92000000000109, 62.01000000000109, 62.100000000001096, 62.1900000000011, 62.2800000000011, 62.370000000001106, 62.46000000000111, 62.55000000000111, 62.640000000001116, 62.73000000000112, 62.82000000000112, 62.910000000001126, 63.00000000000113, 63.09000000000113, 63.18000000000114, 63.27000000000114, 63.36000000000114, 63.45000000000115, 63.54000000000115, 63.630000000001154, 63.72000000000116, 63.81000000000116, 63.900000000001164, 63.99000000000117, 64.08000000000116, 64.17000000000117, 64.26000000000117, 64.35000000000117, 64.44000000000118, 64.53000000000118, 64.62000000000118, 64.71000000000119, 64.80000000000119, 64.8900000000012, 64.9800000000012, 65.0700000000012, 65.1600000000012, 65.25000000000121, 65.34000000000121, 65.43000000000121, 65.52000000000122, 65.61000000000122, 65.70000000000122, 65.79000000000123, 65.88000000000123, 65.97000000000124, 66.06000000000124, 66.15000000000124, 66.24000000000125, 66.33000000000125, 66.42000000000125, 66.51000000000126, 66.60000000000126, 66.69000000000126, 66.78000000000127, 66.87000000000127, 66.96000000000127, 67.05000000000128, 67.14000000000128, 67.23000000000128, 67.32000000000129, 67.41000000000129, 67.5000000000013, 67.5900000000013, 67.6800000000013, 67.7700000000013, 67.8600000000013, 67.95000000000131, 68.04000000000131, 68.13000000000132, 68.22000000000132, 68.31000000000132, 68.40000000000133, 68.49000000000133, 68.58000000000133, 68.67000000000134, 68.76000000000134, 68.85000000000134, 68.94000000000135, 69.03000000000135, 69.12000000000135, 69.21000000000136, 69.30000000000136, 69.39000000000136, 69.48000000000137, 69.57000000000137, 69.66000000000138, 69.75000000000138, 69.84000000000138, 69.93000000000139, 70.02000000000139, 70.11000000000139, 70.2000000000014, 70.2900000000014, 70.3800000000014, 70.4700000000014, 70.56000000000141, 70.65000000000141, 70.74000000000142, 70.83000000000142, 70.92000000000142, 71.01000000000143, 71.10000000000143, 71.19000000000143, 71.28000000000144, 71.37000000000144, 71.46000000000144, 71.55000000000145, 71.64000000000145, 71.73000000000145, 71.82000000000146, 71.91000000000146, 72.00000000000146, 72.09000000000147, 72.18000000000147, 72.27000000000147, 72.36000000000148, 72.45000000000148, 72.54000000000148, 72.63000000000149, 72.72000000000149, 72.8100000000015, 72.9000000000015, 72.9900000000015, 73.0800000000015, 73.17000000000151, 73.26000000000151, 73.35000000000151, 73.44000000000152, 73.53000000000152, 73.62000000000153, 73.71000000000153, 73.80000000000153, 73.89000000000154, 73.98000000000154, 74.07000000000154, 74.16000000000155, 74.25000000000155, 74.34000000000155, 74.43000000000156, 74.52000000000156, 74.61000000000156, 74.70000000000157, 74.79000000000157, 74.88000000000157, 74.97000000000158, 75.06000000000158, 75.15000000000158, 75.24000000000159, 75.33000000000159, 75.4200000000016, 75.5100000000016, 75.6000000000016, 75.6900000000016, 75.7800000000016, 75.87000000000161, 75.96000000000161, 76.05000000000162, 76.14000000000162, 76.23000000000162, 76.32000000000163, 76.41000000000163, 76.50000000000163, 76.59000000000164, 76.68000000000164, 76.77000000000164, 76.86000000000165, 76.95000000000165, 77.04000000000165, 77.13000000000166, 77.22000000000166, 77.31000000000166, 77.40000000000167, 77.49000000000167, 77.58000000000168, 77.67000000000168, 77.76000000000168, 77.85000000000169, 77.94000000000169, 78.03000000000169, 78.1200000000017, 78.2100000000017, 78.3000000000017, 78.3900000000017, 78.48000000000171, 78.57000000000171, 78.66000000000172, 78.75000000000172, 78.84000000000172, 78.93000000000173, 79.02000000000173, 79.11000000000173, 79.20000000000174, 79.29000000000174, 79.38000000000174, 79.47000000000175, 79.56000000000175, 79.65000000000175, 79.74000000000176, 79.83000000000176, 79.92000000000176, 80.01000000000177, 80.10000000000177, 80.19000000000177, 80.28000000000178, 80.37000000000178, 80.46000000000178, 80.55000000000179, 80.64000000000179, 80.7300000000018, 80.8200000000018, 80.9100000000018, 81.0000000000018, 81.09000000000181, 81.18000000000181, 81.27000000000182, 81.36000000000182, 81.45000000000182, 81.54000000000183, 81.63000000000183, 81.72000000000183, 81.81000000000184, 81.90000000000184, 81.99000000000184, 82.08000000000185, 82.17000000000185, 82.26000000000185, 82.35000000000186, 82.44000000000186, 82.53000000000186, 82.62000000000187, 82.71000000000187, 82.80000000000187, 82.89000000000188, 82.98000000000188, 83.07000000000188, 83.16000000000189, 83.25000000000189, 83.3400000000019, 83.4300000000019, 83.5200000000019, 83.6100000000019, 83.7000000000019, 83.79000000000191, 83.88000000000191, 83.97000000000192, 84.06000000000192, 84.15000000000192, 84.24000000000193, 84.33000000000193, 84.42000000000193, 84.51000000000194, 84.60000000000194, 84.69000000000194, 84.78000000000195, 84.87000000000195, 84.96000000000195, 85.05000000000196, 85.14000000000196, 85.23000000000197, 85.32000000000197, 85.41000000000197, 85.50000000000198, 85.59000000000198, 85.68000000000198, 85.77000000000199, 85.86000000000199, 85.95000000000199, 86.040000000002, 86.130000000002, 86.220000000002, 86.310000000002, 86.40000000000201, 86.49000000000201, 86.58000000000202, 86.67000000000202, 86.76000000000202, 86.85000000000203, 86.94000000000203, 87.03000000000203, 87.12000000000204, 87.21000000000204, 87.30000000000204, 87.39000000000205, 87.48000000000205, 87.57000000000205, 87.66000000000206, 87.75000000000206, 87.84000000000206, 87.93000000000207, 88.02000000000207, 88.11000000000207, 88.20000000000208, 88.29000000000208, 88.38000000000208, 88.47000000000209, 88.56000000000209, 88.6500000000021, 88.7400000000021, 88.8300000000021, 88.9200000000021, 89.01000000000211, 89.10000000000211, 89.19000000000212, 89.28000000000212, 89.37000000000212, 89.46000000000213, 89.55000000000213, 89.64000000000213, 89.73000000000214, 89.82000000000214, 89.91000000000214]; thicknessArray = [30.0, 29.986119342238435, 29.972783341211088, 29.95998390795658, 29.947712953513516, 29.935962388920476, 29.924724125216073, 29.91399007343892, 29.903752144627596, 29.89400224982071, 29.884732300056857, 29.875934206374648, 29.867599879812676, 29.859721231409544, 29.852290172203855, 29.845298613234206, 29.838738465539187, 29.832601640157424, 29.8268800481275, 29.821565600488015, 29.81665020827758, 29.812125782534775, 29.807984234298225, 29.804217474606517, 29.800817414498248, 29.79777596501203, 29.795085037186457, 29.792736542060123, 29.790722390671654, 29.78903449405962, 29.787664763262633, 29.786605109319293, 29.785847443268207, 29.785383676147966, 29.785205718997172, 29.785305482854444, 29.785674878758353, 29.786305817747518, 29.787190210860526, 29.788319969136, 29.789687003612517, 29.79128322532869, 29.79310054532311, 29.795130874634392, 29.797366124301128, 29.799798205361913, 29.802419028855358, 29.80522050582006, 29.80819454729461, 29.81133306431763, 29.8146279679277, 29.818071169163428, 29.821654579063416, 29.825370108666263, 29.829209669010567, 29.83316517113493, 29.837228526077958, 29.84139164487825, 29.845646438574388, 29.849984818204998, 29.85439869480867, 29.858879979424003, 29.8634205830896, 29.868012416844063, 29.87264739172599, 29.877317418773973, 29.882014409026628, 29.886730273522552, 29.891456923300332, 29.896186269398587, 29.900910222855906, 29.90562069471089, 29.91030959600215, 29.914968837768267, 29.919590331047864, 29.924165986879522, 29.928687716301855, 29.933147430353458, 29.937537040072925, 29.941848456498874, 29.94607359066989, 29.950204353624578, 29.95423265640153, 29.958150410039366, 29.96194952557667, 29.96562191405206, 29.969159486504118, 29.972554153971444, 29.975797827492656, 29.97888241810634, 29.981799836851096, 29.984541994765532, 29.987100802888257, 29.98946817225784, 29.99163601391291, 29.993596238892053, 29.995340758233887, 29.996861482977, 29.99815032415999, 29.999199192821457, 30.000000000000007, 30.00054465673425, 30.000825074062764, 30.000833163024154, 30.000560834657037, 30.0, 29.999201889141922, 29.998455008372694, 29.998107183032516, 29.998506238461548, 30.000000000000004, 30.00287592414882, 30.007179992052183, 30.012897816015055, 30.0200150083424, 30.02851718133918, 30.03838994731036, 30.049618918560896, 30.06218970739576, 30.076087926119914, 30.091299187038317, 30.107809102455935, 30.125603284677737, 30.14466734600869, 30.164986898753735, 30.186547555217846, 30.209334927706006, 30.233334628523156, 30.258532269974268, 30.28491346436431, 30.312463823998232, 30.341168961181005, 30.371014488217597, 30.401986017412963, 30.434069161072085, 30.467249531499903, 30.501512741001388, 30.536844401881506, 30.57323012644522, 30.610655526997498, 30.649106215843293, 30.68856780528758, 30.72902590763531, 30.77046613519147, 30.812874100261, 30.856235415148866, 30.900535692160037, 30.945760543599484, 30.99189558177216, 31.038926418983024, 31.08683866753705, 31.135617939739202, 31.185249847894436, 31.235720004307726, 31.287014021284026, 31.3391175111283, 31.392016086145517, 31.445695358640638, 31.50014094091863, 31.555338445284434, 31.611273484043053, 31.66793166949942, 31.725298613958522, 31.78335992972529, 31.842101229104717, 31.90150812440176, 31.961566227921367, 32.02226115196852, 32.08357850884818, 32.1455039108653, 32.20802297032485, 32.27112129953179, 32.334784510791096, 32.39899821640771, 32.463748028686624, 32.529019559932784, 32.59479842245114, 32.66107022854669, 32.72782059052436, 32.79503512068914, 32.86269943134599, 32.930799134799855, 32.999319843355714, 33.068247169318546, 33.137566724993285, 33.20726412268491, 33.27732497469839, 33.34773489333867, 33.41847949091072, 33.48954437971952, 33.56091517207001, 33.632577480267166, 33.70451691661596, 33.776719093421335, 33.84916962298827, 33.92185411762172, 33.99475818962665, 34.06786745130803, 34.141167514970824, 34.21464399291998, 34.28828249746047, 34.36206864089728, 34.43598803553534, 34.51002629367963, 34.584169027635106, 34.658401849706735, 34.732710372199485, 34.807080207418316, 34.881496967668184, 34.95594626525408, 35.030413712480936, 35.10488492165372, 35.179345505077414, 35.25378107505696, 35.32817724389735, 35.402519623903515, 35.476793827380426, 35.55098546663307, 35.62508015396639, 35.69906350168535, 35.772921122094914, 35.84663862750006, 35.92020163020573, 35.9935957425169, 36.06680657673854, 36.1398197451756, 36.21262086013304, 36.28519553391585, 36.357529378828964, 36.42960800717736, 36.501417031265994, 36.57294206339984, 36.64416871588386, 36.715082601023006, 36.78566933112225, 36.85591451848655, 36.925803775420874, 36.9953227142302, 37.06445694721946, 37.13319208669365, 37.201513744957715, 37.26940753431661, 37.33685906707531, 37.40385395553879, 37.470377812012, 37.53641624879991, 37.60195487820747, 37.66697931253966, 37.73147516410144, 37.79542804519775, 37.8588235681336, 37.92164734521391, 37.98388498874368, 38.045522111027836, 38.10654432437136, 38.16693724107922, 38.22668647345638, 38.28577763380779, 38.34419633443843, 38.40192818765325, 38.45895880575723, 38.515273801055315, 38.570858785852465, 38.62569937245367, 38.679781173163875, 38.73308980028804, 38.78561086613114, 38.83732998299814, 38.888232763194, 38.93830481902366, 38.98753176279212, 39.03589920680433, 39.083392763365254, 39.129998044779846, 39.17570066335308, 39.22048623138991, 39.264340361195316, 39.30724866507425, 39.34919675533166, 39.390170244272554, 39.43015474420186, 39.46913586742455, 39.50709922624557, 39.54403043296991, 39.579915099902536, 39.61473883934839, 39.64848726361245, 39.681145984999674, 39.712700615815024, 39.743136768363456, 39.77244005494996, 39.80059608787949, 39.82759047945699, 39.85340884198744, 39.87803678777579, 39.90145992912702, 39.92366387834608, 39.94463424773796, 39.96435664960759, 39.98281669625995, 39.99999999999999, 40.015896135405, 40.030510526141285, 40.043852558147535, 40.0559316173624, 40.06675708972454, 40.07633836117259, 40.08468481764519, 40.09180584508104, 40.097710829418745, 40.10240915659698, 40.10591021255439, 40.10822338322964, 40.10935805456137, 40.109323612488225, 40.108129442948886, 40.10578493188196, 40.10229946522615, 40.09768242892008, 40.0919432089024, 40.08509119111177, 40.07713576148684, 40.06808630596628, 40.057952210488715, 40.04674286099281, 40.034467643417216, 40.021135943700585, 40.006757147781556, 39.99134064159882, 39.97489581109099, 39.95743204219673, 39.93895872085471, 39.919485233003556, 39.899020964581936, 39.8775753015285, 39.8551576297819, 39.831777335280776, 39.80744380396379, 39.782166421769595, 39.75595457463687, 39.72881764850421, 39.70076502931032, 39.67180610299382, 39.64195025549338, 39.611206872747644, 39.57958534069525, 39.54709504527488, 39.513745372425184, 39.479545708084785, 39.44450543819236, 39.40863394868655, 39.371940625506014, 39.334434854589404, 39.296126021875374, 39.25702351330256, 39.21713671480965, 39.17647501233526, 39.13504779181805, 39.092864439196696, 39.04993434040982, 39.0062668813961, 38.96187144809416, 38.91675742644267, 38.87093420238028, 38.82441116184566, 38.77719769077742, 38.729303175114254, 38.680737000794785, 38.63150855375768, 38.5816272199416, 38.53110238528519, 38.47994343572709, 38.428159757205954, 38.37576073566045, 38.32275575702922, 38.26915420725092, 38.2149654722642, 38.16019893800771, 38.104863990420114, 38.04897001544005, 37.99252639900618, 37.93554252705714, 37.8780277855316, 37.81999156036821, 37.76144323750562, 37.7023922028825, 37.64284784243745, 37.58281954210917, 37.5223166878363, 37.461348665557495, 37.399924861211396, 37.33805466073668, 37.27574745007197, 37.21301261515593, 37.14985954192721, 37.08629761632448, 37.02233622428635, 36.95798475175152, 36.89325258465862, 36.828149108946306, 36.762683710553226, 36.69686577541803, 36.63070468947939, 36.564209838675936, 36.497390608946326, 36.43025638622922, 36.362816556463265, 36.2950805055871, 36.22705761953941, 36.15875728425881, 36.09018888568398, 36.02136180975358, 35.952285442406215, 35.882969169580576, 35.81342237721532, 35.74365445124907, 35.6736747776205, 35.603492742268266, 35.53311773113099, 35.46255913014737, 35.39182632525602, 35.320928702395605, 35.24987564750479, 35.17867654652221, 35.107340785386526, 35.035877750036384, 34.96429682641044, 34.892607400447346, 34.82081885808576, 34.74894058526432, 34.67698196792169, 34.60495239199653, 34.53286124342747, 34.46071790815318, 34.388531772112295, 34.31631222124349, 34.244068641485406, 34.171810418776694, 34.09954693905602, 34.02728758826201, 33.95504175233333, 33.882818817208644, 33.81062816882658, 33.73847919312581, 33.66638127604499, 33.59434380352275, 33.52237616149776, 33.450487735908666, 33.37868791269412, 33.30698607779278, 33.235391617143286, 33.163913916684315, 33.09256236235449, 33.021346340092485, 32.95027523583693, 32.8793584355265, 32.80860532509984, 32.73802529049559, 32.66762771765242, 32.59742199250899, 32.52741750100392, 32.45762362907588, 32.388049762663535, 32.31870528770551, 32.249599590140484, 32.18074205590709, 32.11214207094399, 32.04380902118983, 31.975752292583273, 31.907981271062962, 31.840505342567553, 31.773333893035698, 31.706476308406053, 31.63994197461726, 31.573740277607985, 31.507880603316863, 31.442372337682563, 31.37722486664373, 31.31244757613901, 31.248049852107073, 31.18404108048655, 31.12043064721611, 31.0572279382344, 30.994442339480074, 30.932083236891778, 30.870160016408164, 30.808682063967904, 30.74765876550962, 30.687099506971983, 30.627013674293647, 30.567410653413255, 30.508299830269458, 30.44969059080092, 30.391592320946295, 30.33401440664421, 30.276966233833353, 30.220457188452343, 30.16449665643986, 30.109094023734535, 30.054258676275033, 30.0, 29.946325542838572, 29.893235500681758, 29.840728231411084, 29.78880209290802, 29.73745544305409, 29.686686639730784, 29.636494040819603, 29.586876004202047, 29.53783088775962, 29.489357049373826, 29.441452846926143, 29.3941166382981, 29.34734678137118, 29.30114163402689, 29.25549955414674, 29.210418899612197, 29.1658980283048, 29.121935298106028, 29.078529066897392, 29.03567769256038, 28.99337953297649, 28.951632946027253, 28.910436289594138, 28.86978792155865, 28.82968619980229, 28.790129482206567, 28.751116126652988, 28.71264449102304, 28.67471293319822, 28.637319811060028, 28.600463482489978, 28.564142305369565, 28.52835463758028, 28.493098837003632, 28.45837326152113, 28.424176269014243, 28.39050621736451, 28.35736146445341, 28.324740368162452, 28.29264128637312, 28.261062576966935, 28.23000259782539, 28.19945970682997, 28.169432261862198, 28.139918620803563, 28.110917141535577, 28.082426181939724, 28.05444409989751, 28.026969253290435, 28.000000000000007, 27.973534030947693, 27.947566369214876, 27.922091370922903, 27.89710339219312, 27.872596789146904, 27.848565917905596, 27.825005134590544, 27.801908795323097, 27.77927125622462, 27.757086873416466, 27.735350003019974, 27.71405500115651, 27.69319622394742, 27.67276802751407, 27.65276476797779, 27.63318080145995, 27.6140104840819, 27.595248171964986, 27.576888221230575, 27.558924987999998, 27.541352828394636, 27.52416609853583, 27.507359154544915, 27.49092635254327, 27.47486204865223, 27.45916059899316, 27.443816359687407, 27.428823686856322, 27.414176936621264, 27.399870465103582, 27.385898628424627, 27.372255782705764, 27.358936284068328, 27.34593448863368, 27.33324475252318, 27.32086143185817, 27.30877888276001, 27.296991461350046, 27.28549352374964, 27.27427942608015, 27.263343524462893, 27.25268017501926, 27.242283733870604, 27.232148557138256, 27.22226900094358, 27.21263942140793, 27.203254174652653, 27.194107616799112, 27.185194103968644, 27.17650799228262, 27.16804363786238, 27.159795396829292, 27.151757625304686, 27.143924679409935, 27.136290915266386, 27.128850688995378, 27.121598356718284, 27.114528274556456, 27.10763479863123, 27.10091228506398, 27.09435508997604, 27.087957569488772, 27.08171407972353, 27.075618976801657, 27.06966661684453, 27.063851355973476, 27.058167550309857, 27.052609555975035, 27.047171729090344, 27.041848425777157, 27.036634002156813, 27.031522814350662, 27.02650921848008, 27.021587570666398, 27.01675222703097, 27.01199754369516, 27.00731787678032, 27.00270758240779, 26.998161016698937, 26.993672535775097, 26.989236495757645, 26.98484725276793, 26.980499162927277, 26.976186582357073, 26.971903867178657, 26.96764537351339, 26.963405457482605, 26.959178475207676, 26.954958782809943, 26.95074073641076, 26.946518692131495, 26.942287006093483, 26.93804003441809, 26.93377213322665, 26.929477658640533, 26.92515096678109, 26.920786413769672, 26.91637835572763, 26.91192114877632, 26.907409149037086, 26.902836712631302, 26.89819819568029, 26.893487954305424, 26.888700344628063, 26.883829722769548, 26.878870444851227, 26.873816866994463, 26.868663345320602, 26.86340423595101, 26.858033895007022, 26.852546678610004, 26.846936942881303, 26.84119904394227, 26.83532733791427, 26.829316180918642, 26.823159929076734, 26.816852938509932, 26.810389565339555, 26.803764165686964, 26.796971095673516, 26.79000471142056, 26.782859369049465, 26.775529424681555, 26.76800923443821, 26.760293154440767, 26.752375540810583, 26.74425074966901, 26.735913137137413, 26.727357059337123, 26.718576872389505, 26.709566932415918, 26.700321595537716, 26.690835217876227, 26.681102155552832, 26.67111676468887, 26.66087340140569, 26.650366421824664, 26.639590182067128, 26.628539038254445, 26.61720734650796, 26.605589462949027, 26.593679743699, 26.58147254487924, 26.568962222611077, 26.556143133015897, 26.54300963221503, 26.52955607632983, 26.515776821481666, 26.501666223791865, 26.4872186393818, 26.472428424372822, 26.457289934886276, 26.441797527043526, 26.42594555696591, 26.409728380774794, 26.393140354591527, 26.376175834537456, 26.35882917673394, 26.341094737302342, 26.322966872363992, 26.304439938040257, 26.285508290452494, 26.266166285722036, 26.246408279970268, 26.226228629318513, 26.205621689888137, 26.184581817800495, 26.16310336917693, 26.14118070013881, 26.118808166807472, 26.09598012530428, 26.072690931750586, 26.04893494226774, 26.02470651297709, 25.999999999999996, 25.9748136193137, 25.949161026318986, 25.923059736272542, 25.89652726443105, 25.869581126051173, 25.842238836389612, 25.814517910703042, 25.786435864248133, 25.758010212281565, 25.72925847006004, 25.700198152840212, 25.67084677587877, 25.641221854432402, 25.611340903757775, 25.581221439111577, 25.55088097575049, 25.520337028931184, 25.489607113910353, 25.45870874594467, 25.4276594402908, 25.39647671220545, 25.36517807694528, 25.333781049766994, 25.302303145927237, 25.270761880682716, 25.239174769290102, 25.207559327006077, 25.175933069087318, 25.1443135107905, 25.112718167372314, 25.081164554089437, 25.049670186198547, 25.018252578956332, 24.98692924761946, 24.955717707444606, 24.924635473688472, 24.893700061607717, 24.86292898645904, 24.8323397634991, 24.80194990798459, 24.77177693517219, 24.741838360318578, 24.712151698680433, 24.682734465514432, 24.65360417607727, 24.62477834562561, 24.596274489416132, 24.568110122705527, 24.54030276075047, 24.512869918807635, 24.485829112133718, 24.459197855985384, 24.432993665619314, 24.4072340562922, 24.38193654326071, 24.357118641781526, 24.332797867111335, 24.308991734506808, 24.285717759224625, 24.262993456521475, 24.240836341654038, 24.21926392987898, 24.198293736453, 24.177943276632757, 24.15823006567495, 24.139171618836244, 24.120785451373333, 24.103089078542887, 24.08610001560159, 24.06983577780612, 24.05431388041316, 24.03955183867939, 24.02556716786148, 24.012377383216126, 24.0, 23.988446490775566, 23.977704157328407, 23.9677542587499, 23.958578054131404, 23.950156802564305, 23.94247176313997, 23.93550419494976, 23.92923535708506, 23.923646508637223, 23.918718908697638, 23.91443381635766, 23.91077249070867, 23.907716190842038, 23.905246175849125, 23.90334370482131, 23.90199003684996, 23.901166431026446, 23.900854146442136, 23.901034442188415, 23.901688577356634, 23.90279781103818, 23.904343402324407, 23.906306610306697, 23.908668694076415, 23.91141091272494, 23.914514525343634, 23.917960791023862, 23.921730968857016, 23.92580631793444, 23.93016809734753, 23.93479756618764, 23.93967598354614, 23.944784608514414, 23.950104700183818, 23.955617517645727, 23.961304319991516, 23.967146366312555, 23.973124915700204, 23.979221227245855, 23.98541656004085, 23.991692173176585, 23.998029325744415, 24.004409276835716, 24.010813285541854, 24.017222610954217, 24.02361851216415, 24.02998224826304, 24.036295078342253, 24.04253826149316, 24.048693056807135, 24.054740723375538, 24.060662520289753, 24.06643970664114, 24.072053541521075, 24.077485284020923, 24.082716193232066, 24.08772752824586, 24.09250054815369, 24.097016512046917, 24.10125667901691, 24.105202308155043, 24.10883465855269, 24.11213498930122, 24.115084559491997, 24.117664628216396, 24.11985645456579, 24.12164129763155, 24.123000416505047, 24.123915070277636, 24.12436651804071, 24.124336018885632, 24.12380483190376, 24.122754216186486, 24.121165430825158, 24.119019734911163, 24.116298387535867, 24.11298264779064, 24.10905377476685, 24.104493027555872, 24.09928166524907, 24.093400946937827, 24.0868321317135, 24.079556478667463, 24.071555246891094, 24.062809695475753, 24.05330108351282, 24.04301067009366, 24.031919714309637, 24.020009475252145, 24.007261212012526, 23.993656183682166, 23.979175649352435, 23.9638008681147, 23.94751309906033, 23.930293601280706, 23.91212363386719, 23.892984455911144, 23.872857326503947, 23.85172350473698, 23.829564249701605, 23.80636082048919, 23.782094476191105, 23.75674647589872, 23.730298078703406, 23.702730543696546, 23.674025129969493, 23.644163096613624, 23.613125702720314, 23.58089420738093, 23.547449869686837, 23.512773948729414, 23.476847703600033, 23.439652393390052, 23.401169277190856, 23.361379614093806, 23.320264663190272, 23.277805683571632, 23.233983934329256, 23.188780674554508, 23.142177163338758, 23.09415465977339, 23.04469442294976, 22.99377771195924, 22.941385785893207, 22.88749990384303, 22.832101324900073, 22.775171308155706, 22.716691112701316, 22.65664199762826, 22.595005222027908, 22.53176204499164, 22.46689372561081, 22.400381522976808, 22.332206696180993, 22.262350504314732, 22.190794206469405, 22.117519061736385, 22.042506329207022, 21.965737267972713, 21.88719313712481, 21.806855195754693, 21.72470470295373, 21.640722917813292, 21.554891099424744, 21.46719050687946, 21.377602399268817, 21.28610803568418, 21.192688675216917, 21.0973255769584, 21.000000000000004, 20.900778518531066, 20.800068967132848, 20.69836449548458, 20.596158253265465, 20.493943390154747, 20.39221305583165, 20.291460399975403, 20.19217857226523, 20.094860722380353, 20.000000000000004, 19.907794527085034, 19.817262314722782, 19.727126346282247, 19.63610960513238, 19.542935074642163, 19.446325738180583, 19.34500457911659, 19.237694580819188, 19.12311872665733, 19.0, 18.867061384216175, 18.723025862674827, 18.566616418744918, 18.39655603579544, 18.211567697195363, 18.010374386313664, 17.791699086519316, 17.55426478118129, 17.29679445366856, 17.01801108735011, 16.71663766559491, 16.39139717177193, 16.04101258925015, 15.664206901398547, 15.25970309158609, 14.82622414318176, 14.362493039554526, 13.867232764073364, 13.339166300107252, 12.777016631025162, 12.179506740196071, 11.545359610988951, 10.873298226772778, 10.162045570916533, 9.41032462678918, 8.616858377759701, 7.780369807197068, 6.899581898470258, 5.973217634948243, 5.0];
Something I wanted to achieve with this project is designing airfoils using OpenSCAD, as a good way to practice for applying this to RC aircraft. Using NREL design recommendations for small wind turbines, I've implemented a turbine blade that incorporates the NREL S835 airfoil at the root, transitioning to the S833 by 30% of the blade length, and then transitioning to the NREL S834 airfoil at 95% of the blade length. The OpenSCAD code uses the hull function to generate a loft through these shapes with a airfoil chord length of 1. The airfoil profiles themselves came from AirfoilTools.com.
Then I use the projection function to slice this airfoil back into 2D polygons at 0.1% intervals of the blade length. I used a cubic spline function in python to generate a smoothed array of turbine blade thicknesses which I copy across to OpenSCAD. This allows me to generate nice smooth variation in turbine blade thickness across its length. Lastly I rotated the blade pitch angle by 45 degrees across the length of the blade. My goal is to build 1000mm long blades, so using the angle of attack data and the average windspeed at my deployment location, I'll incorporate the optimal angle of attack for generating lift data for each of the airfoils, and transition the twist so that at the average windspeed, each "slice" of the airfoil is at it's optimal angle of attack for generating lift. For now however I've just varried the blade pitch angle linearly from 0 at the base to 45 at the tip.
Added Design Document to Repository
04/26/2022 at 13:38 • 0 commentsSo far I've determined the average wind speed of the deployment location from online sources, and added some research documents on turbine airfoil selection from the National Renewable Energy Laboratory.
At this time I will likely use either the NACA 2412 or 4412 airfoils, or one of the NREL S-series airfoils.
Initial Research Questions
03/30/2022 at 12:21 • 0 commentsThe following research questions need to be addressed before detailed design can be commenced.
- Ideal airfoil profile for wind turbine.
- Median Wind Speed in my location (Southern Tasmania) for peak efficiency.
- Turbine RPM at this speed
- Appropriate Brush less motor that can be direct driven or driven using off the shelf gear box.
