tardis_network.h
code for using WiFi shield to trigger actions
h -
7.91 kB -
04/20/2022 at 09:19
Download
ArduinoTARDIS.ino
main program - initializes stuff and starts everything up
ino -
8.64 kB -
04/20/2022 at 09:19
Download
RGB_Pulser.h
Extends Pulser class to work on three LEDs grouped together
h -
2.31 kB -
04/20/2022 at 09:19
Download
example_network_config.h
customize network settings for your Wifi access and adafruit settings.
h -
451.00 bytes -
04/20/2022 at 09:19
Download
tardis_audio.h
Uses Robertson WAVE shield from Adafruit to play wave files.
h -
4.20 kB -
04/20/2022 at 09:19
Download
Flasher.h
Define API to control an LED.
h -
3.19 kB -
04/20/2022 at 09:19
Download
Pulser.h
Extends Flasher to create the visually pleasing brightening and dimming of an LED using the Flasher class.
h -
3.49 kB -
04/20/2022 at 09:19
Download
ir_decoder.h
Start at decoding IR signal.
h -
932.00 bytes -
04/20/2022 at 09:19
Download
atx_shield.h
Code for controlling the ATX shield from Sparkfun. Standby power is used to power the Arduino, control ATX power to drive 6 LED PWM channels.
h -
1.23 kB -
04/20/2022 at 09:19
Download
