Stringy PETG and PLA in a Comparison!
07/16/2022 at 03:05 • 0 commentsI have finally learned how to print in PETG w/ my older model printrBot 1403. I am using the Recore board still w/ Klipper and OctoPrint. Things are going okay but I find that:
1. While printing in PETG, unlike w/ PLA, the prints that build incrementally outward w/out a sound base tend to string out. W/ PLA, unlike PETG, the building of new layers outward tend to adhere a bit more. This entails a solid base per layer when building. PETG is stringy and creates a solid foundation but when there is no foundation, the layering builds upward, even w/ a half a layer build upward, at a non-valid use output.
The output is basically wired in looks and has no real use. Sanding!
Seth
Recore_A5 and Refactor 3.0.3 revision...
04/27/2022 at 08:03 • 0 comments# Recore_1403 config [recore] revision: A5 gain_t0: 1 gain_t1: 1 gain_t2: 1 gain_t3: 1 pullup_t0: 1 pullup_t1: 1 pullup_t2: 1 pullup_t3: 1 #offset_t0: 0 #offset_t1: 0 #offset_t2: 0 #offset_t3: 0 # The STM32F031 mcu [mcu] serial: /dev/ttyS4 baud: 250000 restart_method: command # The AR100 mcu [mcu ar100] serial: /dev/ttyS1 baud: 1500000 #[static_digital_output endstops_5V_enable] #pins: ar100:PG11, ar100:PG8 # pin high = 12V, pin low = 5V [static_digital_output endstop_ES0_5V_12V] pins: ar100:PG11, ar100:PG8 #[static_digital_output temperature_5V_enable] #pins: ar100:PF1 #[static_digital_output over_current_alarm] #pins: !ar100:PG1 [static_digital_output user_led_enable] pins: PA12 #[static_digital_output enable_high_power] #pins: !ar100:PG2 #[static_digital_output thermistor_pullups] #pins: ar100:PD6, ar100:PD24, ar100:PF1 # Load "thermocouple" sensor #[thermocouple] [printer] kinematics: cartesian max_velocity: 500 max_accel: 3000 max_z_velocity: 25 max_z_accel: 10 [tmc2209 stepper_x] uart_pin: ar100:PB1 tx_pin: ar100:PB0 uart_address: 0 run_current: 0.700 #hold_current: 0.500 #microsteps: 16 stealthchop_threshold: 250 driver_internal_rsense: 1 ref_resistor: 6800 [tmc2209 stepper_y] uart_pin: ar100:PB1 tx_pin: ar100:PB0 uart_address: 1 run_current: 0.700 #hold_current: 0.500 #microsteps: 16 stealthchop_threshold: 250 driver_internal_rsense: 1 ref_resistor: 6800 [tmc2209 stepper_z] uart_pin: ar100:PB1 tx_pin: ar100:PB0 uart_address: 2 run_current: 0.700 #hold_current: 0.500 #mircosteps: 16 stealthchop_threshold: 250 driver_internal_rsense: 1 ref_resistor: 6800 [tmc2209 extruder] uart_pin: ar100:PB1 tx_pin: ar100:PB0 uart_address: 3 run_current: 0.700 #hold_current: 0.500 #microsteps: 16 stealthchop_threshold: 250 driver_internal_rsense: 1 ref_resistor: 6800 [stepper_x] step_pin: ar100:PL4 dir_pin: ar100:PE8 endstop_pin: ar100:PH5 rotation_distance: 35 microsteps: 16 position_endstop: 0 position_max: 152 homing_speed: 15.0 [stepper_y] step_pin: ar100:PL5 dir_pin: ar100:PE9 endstop_pin: ar100:PH6 rotation_distance: 35 microsteps: 16 position_endstop: 0 position_max: 152 homing_speed: 15.0 # probe [probe] pin: ar100:PH4 z_offset: 0.20 x_offset: 0.0 y_offset: 0.0 [stepper_z] step_pin: ar100:PL6 dir_pin: !ar100:PE10 endstop_pin: probe:z_virtual_endstop #endstop_pin: !ar100:PH6 rotation_distance: 1.50 microsteps: 16 #position_endstop: 0 position_max: 152.0 homing_speed: 8.0 [extruder] step_pin: ar100:PL7 dir_pin: ar100:PE11 heater_pin: PA9 sensor_type: EPCOS 100K B57560G104F sensor_pin: PA1 rotation_distance: 35 microsteps: 16 nozzle_diameter: 0.375 filament_diameter: 1.75 control: pid pid_Kp: 22.2 pid_Ki: 1.08 pid_Kd: 114 min_extrude_temp: 30 min_temp: 0 max_temp: 300 #[extruder1] #step_pin: ar100:PL8 #dir_pin: ar100:PE12 #rotation_distance: 40 #microsteps: 16 #nozzle_diameter: 0.400 #filament_diameter: 1.75 #heater_pin: PA9 #sensor_pin: PA1 #sensor_type: RECORE PT1000 #control: pid #pid_Kp: 22.2 #pid_Ki: 1.08 #pid_Kd: 114 #min_temp: 0 #max_temp: 300 #[extruder2] #step_pin: ar100:PL9 #dir_pin: ar100:PE13 #rotation_distance: 40 #microsteps: 16 #nozzle_diameter: 0.400 #filament_diameter: 1.75 #heater_pin: PA10 #sensor_pin: PA2 #sensor_type: PT100 INA826 #adc_voltage: 3.27 #control: pid #pid_Kp: 22.2 #pid_Ki: 1.08 #pid_Kd: 114 #min_temp: 0 #max_temp: 300 #[heater_bed] #heater_pin: PA11 #sensor_type: EPCOS 100K B57560G104F #sensor_pin: PA3 #control: watermark #min_temp: 0 #max_temp: 300 [fan] pin: PB0 #[output_pin fan1] #pin: PB1 #[output_pin fan2] #pin: PB5 #[output_pin fan3] #pin: PB4 # Set up board voltage, current, temperature. [temperature_sensor board] sensor_type: EPCOS 100K B57560G104F sensor_pin: PA6 max_temp: 110 gcode_id: Board [temperature_sensor cold_junction] sensor_type: EPCOS 100K B57560G104F sensor_pin: PA7 gcode_id: CJ # Vout = Vin * 10K/110K = Vin*11 [adc_temperature v] temperature1: 0.35 voltage1: 0 temperature2: 36.65 voltage2: 3.3 [temperature_sensor voltage] adc_voltage: 3.3 sensor_pin: PA4 sensor_type: v gcode_id: Voltage # 1 A = 20 mV [adc_temperature current] temperature1: 0 voltage1: 0 temperature2: 165 voltage2: 3.3 [temperature_sensor current] adc_voltage: 3.3 sensor_pin: PA5 sensor_type: current max_temp: 20 gcode_id: Current #[gcode_button over_current_alarm] #pin: !ar100:PG1 #press_gcode: M112
