I just put together the BOM for the belt system as an alternative to the ballscrew and in terms of cost saved... there's no cost saved.
Then there's the risk that if the top pulley assemby breaks, the resin cartridges are going to fall down like underengineered lifts in action movies.
Overall, it seems that belts would end up being more expensive than ballscrews.
[16:32] Confirmed:
