[P] Scanner sensor and cable breakout
A project log for Liquid Laminate Lithography 3D Printer [gd0105]
The best of resin with the best of filament; is such a 3D printer possible?
kelvinakelvinA 02/17/2023 at 20:560 Comments
It seems that #Tetrinsic [gd0041] isn't going to be a thing that exists in a reasonable time frame, so I thought I'd get a cheap yet important part (Q8100-60002) of this SecSavr Suspense puzzle to work on in the meantime. I only need 2 in the printer, but when 2pcs cost £12 and 5pcs costs £17 and I could use some spares if I break any, it was an easy decision.
I only got 2 breakout boards though because I doubt I'd break that. Visually, I think I've got the correct pin pitch. The ribbon cable hasn't arrived yet so I can't check for certain.
