Connected trashcan project - presentation.pdf
Connected trashcan - presentation slides
Adobe Portable Document Format -
8.66 MB -
06/02/2022 at 17:32
Preview
sensoring_script.py
Python script of the Raspberry Pi 4B /!\ Change the link to your own database inside
py -
2.67 kB -
06/01/2022 at 09:22
Download
HTML website.zip
Pack of all you need for the website /!\ Change the link to your own database in dashboard.html
x-zip-compressed -
2.33 MB -
06/01/2022 at 09:21
Download
The wiring schem of the project
Portable Network Graphics (PNG) -
75.58 kB -
05/28/2022 at 10:47
Preview
device box.svg
You need to make new holes : - one where you want the LED to be (5mm diameter) - one to have access to the battery and let the wires of the sensor pass (90x25mm)
svg+xml -
10.06 kB -
05/28/2022 at 10:41
Preview
sensor box.svg
You also need to make holes : - one to let the cable pass (10x4mm) - one in front of each sensoring part of the sensor (1.5mm diameter)
svg+xml -
6.85 kB -
05/28/2022 at 10:41
Preview
