2022_12_29_Full_description.pdfA detailed description and operating manual for the V2_0f integrated controller board.Adobe Portable Document Format - 2.03 MB - 12/31/2022 at 06:52 |
2022_12_29_Full_description.docA detailed description and operating manual for the V2_0f integrated controller board.msword - 2.14 MB - 12/31/2022 at 06:49 |
221227_Code_for_V2_0f.zipFunctional code for the V2_0f board. It yet requires some cleanup of the comments and maybe some fine tuning for better usability.x-zip-compressed - 32.14 kB - 12/28/2022 at 19:29 |
Pogo_Board.zipOpen Source files for the Pogo test board (MIT license). Full instructions will follow when tested.x-zip-compressed - 3.62 MB - 10/30/2022 at 19:27 |
v2_0f_board_for_solar_tracking_and_robotics.docxA detailed description of the Magnetic Solar Tracker V2.0f board that also takes robotic applications into account.document - 1.79 MB - 10/23/2022 at 06:40 |
v2_0f_board_for_solar_tracking_and_robotics.pdfA detailed description of the Magnetic Solar Tracker V2.0f board that also takes robotic applications into account.Adobe Portable Document Format - 1.26 MB - 10/23/2022 at 06:40 |
Magnetic_CPV_Tracker_v2_0f_Eagle_CAD_CAM_BOM_documentation.zipComplete data set and documentation for the Magnetic CPV Tracker v2.0f board. You can order assembled boards yourself using the CAM outputs and the BOM file. In case you wish to modify the board layout we provide the Eagle schematic and board file. This is real open source!x-zip-compressed - 852.32 kB - 10/22/2022 at 11:49 |
license.txtMIT licensetext/plain - 1.08 kB - 05/01/2022 at 12:41 |
2022_04_29_Tracker_4_contest.pdfA slightly modified version of the presentation I have given at the CPV-18 conference with annotations concerning the pictures which are also used in the conference paper and which will be published through AIP (public access).Adobe Portable Document Format - 1.35 MB - 04/29/2022 at 16:18 |
2021_08_14_Full_description.pdfDetailed description of how to build and operate the tracker controller based on a few breakout boards. More at https://github.com/solhunterAdobe Portable Document Format - 2.61 MB - 04/28/2022 at 16:40 |
Ruediger F. Loeckenhoff
