See webpage for more details. Requires 141 words of program memory (282 bytes).
An ATtiny13 measures a voltage and steps a stepper for- and backwards
I have once implemented a vertical speed indicator simulator. Such instrument need a zero reference. Then I used an optical interrupter with some code to turn the motor until it reaches the zero position. This technique was borrowed from BSAI book: http://www.mikesflightdeck.com/downloads/BSAI Sample Chapter.pdf
To control the position of the motor wouldn't it be good to find a zero reference at startup?
That would only work if, prior to switching off, the stepper would have to be driven to position 0. That is what I did.
Or to store the last measured analogue voltage in an EEPROM position. Is that what you mean? As I used this machinery to adjust a high-voltage capacitor to the resonance position, I did not think about that yet.
brgs,
gerhard
