1Download and install EasyEDA software
This step is only required if you'd like to edit the PCB files provided here.
2Go to your favorite PCB manufacturer and upload the Gerber file
The Gerber file provided here is ready to upload
3Solder the female headers, resistors and capacitors
While this project encourages modularity, some components like resistors and capacitors are soldered directly to the PCB
4Plug the modules
Plug each module/sensor in its designated spot on the PCB
5Program the ESP32
Have a look at the Arduino file provided here. Some variables will need to be updated to suit your needs
Once ready, just upload it to the ESP32
6Print the case
Use the provided STL files (main body and lid) to 3D print the case
7Paint the case white
In order to avoid yellowing from the sun and to better protect the case from the elements, you may want to give it a few coats of white paint. I used just regular spray paint
8Add some protective mesh behing all case holes
I used some bug net that if usually used for doors and windows but you can use other materials too. This is to avoid getting dust and insects inside the sensors
9Install the solar panel
Install the solar panel and make sure to use a generous amount of sealant underneath it to prevent water from dripping inside the case
10Adjust the trimpots for gas measurements
Move everything inside the box and adjust the trimpots to calibrate the measurements.
Precise calibration wihout a known concentration of each gas is not possible, however the datasheet of the sensor recommends to calibrate the output to 2.5V and you should adjust the trimpots to obtain a value of 2.5V in a day with no pollution (or somewhere in a forest). That will be the reference
Ovidiu
Hello. Nice. I dont see the esp32 program ?
Hi, i wanted to work on optimizing it a little but i got distracted by other projects. I might just upload it as it is
