Added complete BOM
09/28/2022 at 19:35 • 0 commentsHello, i've added a complete list of components needed to recreate this project. You may want to use different values and/or modules if you are designing your own version
Updated instruction list
09/25/2022 at 15:01 • 0 commentsHi guys,
I've added some more details to the build intructions to help recreate this project
Added Arduino code
08/04/2022 at 10:52 • 0 commentsPlease see the files section where you can find the complete Arduino IDE code. You will have to replace some URLs and passwords for it to work
Added STL files
08/01/2022 at 11:44 • 0 commentsPlease check the project and you will find the 2 necessary STL files to 3D print your own case.
Ovidiu
