Hackaday.io Hackaday.io
Sign up Log in
Not so small rover
A robotic rover builds with spare part from hoverboards.
tanguyTanguy
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
5.8k views
9 comments
47 followers
  • Description
  • Details
  • Files 0
  • Components 5
    • View all
  • Logs 43
    • View all
  • Instructions 0
  • Discussion 9
View Gallery
5.8k
9
47
41
Team (1)
  • tanguyTanguy
Join this project's team
MISC
ongoing project
ROBOT rover hoverbord
Related lists
Hoverboard
List of all Hoverboard projects
This project was created on 05/18/2022 and last updated 2 years ago.
Description
Who doesn't want to have a really big remote controlled toy?
It's a big baby of 25kg, with a full aluminum frame, a spring suspension system and 4 motors wheels.
The remote controller is here: https://hackaday.io/project/185425-universal-robot-remote
As proposed by email, i have subscribe this project to the Hack it back challenge: https://hackaday.io/project/186499-hack-it-back-rise-of-the-hoverboard
Components
  • 4 × Old Hoverboard (for the wheels & batteries) (you can find broken one for around 20 buck on ebay)
  • 4 × 400x20x40 aluminium extrusion https://www.systeal.com/fr/profiles-aluminium-6-mm/1226-profile-aluminium-v-slot-20x40-fente-6-mm.html
  • 4 × 16kg Spring D1.8mm L62mm
  • 8 × 6206-2RS 30 x 62 x 16 mm bearing https://www.amazon.fr/gp/product/B07LD1D94T/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
  • 100 × M6x70mm screw https://www.amazon.fr/gp/product/B0953HFFKT/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1
Project Logs
Collapse
  • 4 New big wheels !
    Tanguy • 10/08/2024 at 11:04 • 0 comments
  • Work in progress
    Tanguy • 10/08/2024 at 11:03 • 0 comments
  • back on this !
    Tanguy • 03/20/2024 at 09:38 • 0 comments
    I've been busy for a long time, but now I'm back on this project!
    Here is the new frame (building 2 of them)
  • New "all in one" 3d printed part for the legs
    Tanguy • 04/13/2023 at 15:32 • 0 comments
    New "all in one" 3d printed part for the legs :
  • New metal parts! This time in stainless steel of 4mm.
    Tanguy • 04/07/2023 at 11:00 • 0 comments
    Hope it doesn't bend like the 5mm aluminium one.
    Thanks to John steel https://www.john-steel.com for the cutouts !
  • Silent bloc everywhere
    Tanguy • 04/06/2023 at 08:45 • 0 comments
    Given the results of the last test, I am trying to place shocs/vibrations absorber on each leg and on the electronics compartment
  • Aaaaaaand... Some parts bend.
    Tanguy • 02/17/2023 at 00:00 • 0 comments
    Look like 5mm aluminum wasn't enough..
    I am thinking about using 4mm Inox for the next version !
  • First test outside !
    Tanguy • 02/15/2023 at 11:24 • 0 comments
    (Sorry for the vidéo low quality)
  • bigger wheels !
    Tanguy • 01/30/2023 at 21:27 • 0 comments
    I have buy an hoverboard with bigger wheels, i am gonna search for a second one and put 4 of those big wheels on the robot.
  • RC control ! 4 motors, 10% power
    Tanguy • 10/14/2022 at 21:33 • 0 comments
    All the 4 motor are now wired, i use 10% power for testing. This thing is waaaay too powerful, need to take it outside.
View all 43 project logs
Log In/Sign up to comment
Sign up with Github
OR
derkaputte wrote 05/30/2024 at 17:01 • point
How do you get the wheel-speed?There is no encoder. The puls-output is not enough, I think.
And the direction of the wheels are not detected.
Tanguy wrote 10/08/2024 at 10:52 • point
The wheel has a built-in Hall sensor, which provides decent speed feedback !
The main challenge is finding an affordable electronics board that can properly control the motors (and handle the feedback). The controllers I’m currently using are very cheap.. But I’m exploring the possibility of using the original hoverboard PCBs itself. There is some custom firmwares for it, by flashing the STM32 (like this one https://github.com/lucysrausch/hoverboard-firmware-hack/tree/master )
buniakesteban wrote 10/08/2024 at 18:07 • point
I was able to use the original PCBs that came with the hovers flashing this firmware: https://github.com/EFeru/hoverboard-firmware-hack-FOC
It works great, it's fairly easy to do, and the best is that it supports different operating modes for the wheels!
Upkie wheeled bipeds wrote 04/22/2023 at 11:49 • point
Great project! What's next now that you had some successful driving tests?
Tanguy wrote 04/24/2023 at 11:04 • point
Thank ! The driving tests was a success, but some aluminium part of the frame bend.
I am right now fixing this by replacing them by steel parts, and improving some 3d design.
Next step is adding some electronics (GPS, imu, camera, sensors, 4g modem) and some software to remote control it like a drone. ^^
Gianluca wrote 06/13/2022 at 18:55 • point
man I really like this project I also have two hoverboards laying around and I was thinking of doing something with them and this project really helped me thanks bro I really want more updates keep making them come
Tanguy wrote 08/07/2022 at 18:16 • point
Thanks ! I will continue to post project updates.
I hope to be able to do the first driving test soon.
ThanhTran wrote 06/03/2022 at 19:41 • point
Looks very intriguing.  Quite different between the first and second version. Please keep the update and pictures coming
Tanguy wrote 06/03/2022 at 19:51 • point
Thanks ! Yes I changed my mind for 2 reasons 1) The cost, lot of different metal parts is more expensive to buy than 8x the same parts 2) I was afraid of having a lot of mechanical backlash with all the joints, and not being able to put bearings everywhere.
The 2016 Hackaday Prize
This is my robot arm, with recycled materials, can pick 2 Kg and costs around 100$
Project Owner Contributor
D.I.M.E.R PROJECT 6 DOF Robot Arm
antonio-regueiraAntonio Regueira
The 2017 Hackaday Prize
He is a 3D printed robot and an example of a prototype who represents a new form of sketching, design, and create
EMME "Technology is not complicated"
salvador-hurtado-aliaSalvador Hurtado Alia
Hackaday Prize 2020
Mostly 3D printed HAWT windturbine incl. 3D printed disk-generator and brake system.
WinDIY - HAWT Wind turbine
fabianFabian
DIY DLP 3D Printer based on NanoDLP Software using Raspberry Pi 3 and Trinamic Motor Controller
ADAM DLP 3D Printer
adambrxadambrx
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Not so small rover", please tell us the reason.
Send message
Remove Member
